Gå til indhold
Organization Settings
Translate in Crowdin
You can view and manage settings for your Crowdin Enterprise organization using the Organization Settings page.
Manage organization info, authentication, and security settings, view billing history, install Crowdin apps, and more. You can also switch to Permission granularity mode to manage settings for each project group separately.
To configure organization details, click on your profile picture in the upper-right corner and select Organization Settings.
Manage the essential details of your organization, including its name, description, logo, and public presence. You can update your organization’s name and upload a new logo, ensuring your organization’s branding is always current. The Description is a plain-text field that can also be used as context for AI features, and it’s shown to organization members in the About organization dialog.
See the Organization API to learn how to retrieve your organization’s details, such as its name and description, programmatically.
In the Public Organization section, manage how your organization is presented to the public. Add a description, select the project view (List or Grid), and choose up to six featured projects to showcase.
A public page is automatically created when you publish a project with the Crowdsourcing workflow step.
If you are a Vendor, your organization info will be visible to your Clients, and you will also see their organization info.
Configure a Custom Domain to point your own domain to your Crowdin Enterprise organization. When visitors open your custom domain, they are redirected to your organization’s address on Crowdin Enterprise.
To set up a custom domain, create a CNAME record with your DNS provider that points to org.cname.crowdin.com. Ensure that you use this specific address without modifications, as the domain specified below will be automatically detected.
Configure the default settings that apply across your organization. You can set defaults for the Editor view and the sidebar menu, and optionally lock each setting to enforce it for all users.
Choose the default view mode (Side-by-Side, Comfortable, Multilingual, or Multilingual (Grid)) for the Editor across your organization. You can lock this setting to enforce the selected view for all users, preventing any individual changes in their Editor settings.
Set the default order and visibility of the sidebar menu items for all users. The list includes both default navigation sections and any installed apps that add a navigation item. By default, users can override these defaults in their own Customize Menu settings.
To enforce the configured menu for everyone, select Lock this setting. When locked, users can’t customize their own menu in their account settings. Content in hidden items remains safe and accessible.
To reset the menu order and visibility to their default settings, scroll down to the bottom of the list and click Reset to defaults.
The Security section allows you to configure how users join and access your organization. You can fine-tune security settings and manage various authentication methods based on your preferences.
With Security options, you can enhance your organization’s security by enabling features like two-factor authentication, which requires users to verify their identity through an additional step. Additionally, configure the IP allowlist to restrict access to only connections from approved IP addresses, helping maintain strict control over access to your organization’s resources.
You can also manage authentication methods for user sign-ins. Use Crowdin Enterprise’s built-in options or choose from various external methods, including social logins via Google, Facebook, GitHub, GitLab, and X. For advanced security, enable Passkey for a passwordless experience or integrate with existing identity providers using OpenID Connect and SAML. These options simplify the authentication process while ensuring robust security for your organization.
Read more about Security.
In the Billing section, you can manage your subscription plan, track plan limits and usage, view payment history, and handle app subscriptions. You can upgrade or downgrade your plan, and review your organization’s usage and invoices.
Review your current plan: its name and the date you switched to it. The status next to the plan name shows the state of your subscription:
  • Active: The subscription is active and set to renew.
  • Limits Exceeded: Usage has gone over the plan limits. Upgrade the plan to keep your projects active.
  • Suspended: The subscription won’t renew. Your data is kept, and you can renew at any time.
  • Terminated: The subscription has ended. To translate again, buy a new subscription.
Depending on your plan, the section also shows the following figures:
  • Prepaid Balance: The amount left from an annual payment, which Crowdin Enterprise deducts from each month. If the balance won’t cover the next deduction, the amount is highlighted and shows how much is missing.
  • Balance Deduction or Next Charge Total: What will be deducted from the prepaid balance, or what you’ll be charged, on the next billing date. Hover over the amount to see it split into the plan, app subscriptions, and CDN Distributions.
  • Deduction Date, Expiration Date, or Next Charge Date: When the next deduction or payment is due.
  • Renews on or Expiration Date: When the plan renews or ends.
  • Yearly Price: The approximate cost of a year on the current plan, calculated as the monthly plan and app subscription costs multiplied by 12. CDN Distributions are billed by usage and stay out of this figure, which is why it’s preceded by ≈.
The Payment Method row names the provider your subscription is billed through. To change your billing and card details, click Update payment details in that row.
Use Change plan to move to another plan, Renew to resume a suspended subscription, or Suspend to stop future charges.
Review what your plan includes and how much of it your organization uses. The table has three columns:
  • Plan Feature: The resource or feature, such as hosted words, managers, permission granularity, SAML, or IP allowlist.
  • Current Usage/Status: How much your organization uses, or whether the feature is enabled.
  • Plan Limit/Availability: The limit your plan allows, or whether the feature is available on it. Managers are broken down per role when permission granularity is enabled.
Below the table, you can compare plans and upgrade.
Crowdin Store offers various apps that you can install to extend the functionality of Crowdin Enterprise, synchronize your content stored in a CMS, and more. Some of the apps are available for free, while others are paid.
Read more about App Subscriptions.
Access payment history and download invoices.
Set a daily balance warning threshold for CDN Distributions and view the usage statistics.
Read more about CDN Distributions.
Top up your Crowdin Credits balance for paid services (including AI models), set a balance warning threshold, view usage statistics for each service, and set application spending limits.
Read more about Crowdin Credits.
In the Apps section, manage the Crowdin Apps installed in your organization. You can view and manage currently installed apps, search for specific ones, and use the Edit or Uninstall options by clicking on each app.
Click Install from store to add apps developed by Crowdin and other developers from the Crowdin Store. Alternatively, click Install private app to manually install custom apps of your own development.
Read more about Installing Crowdin Apps.
Manage bots for custom applications that interact with Crowdin Enterprise. Bots allow applications to perform specific actions on your behalf within the platform. You can add Bots from the Crowdin Store and manage their permissions to projects and resources as needed.
In the Custom QA Checks section, create, add, and manage QA checks tailored to your specific needs. These QA checks help verify translations against rules not covered by default checks. Manage your installed QA checks by viewing, updating, or deleting them as needed.
Create Custom QA Checks from scratch using a JavaScript-based code snippet, or add pre-made ones from the Crowdin Store. Additionally, install External QA checks as Crowdin Apps from the Crowdin Store to extend your organization’s QA capabilities.
Once added, assign these QA checks to your projects.
Integrate custom spellcheckers to enhance translation quality by checking translations against specialized rules not covered by default settings. You can add spellcheckers from the Crowdin Store and manage their settings, including reviewing supported languages and real-time verification mode.
In the Webhooks section, you can configure organization webhooks to receive notifications about key events that happen in your organization. Once set up, Crowdin Enterprise will send POST or GET requests with data to the specified webhook URL via HTTP when these events occur.
You can create organization webhooks for the following event types:
  • Group created
  • Group deleted
  • Project created
  • Project deleted
Read more about Webhooks.
In the User Access Tokens section, organization owners and admins can view and manage all personal access tokens created by members of the organization. This centralized view allows you to monitor token usage and revoke any token to enhance security.
Read more about User Access Tokens.
In the Custom Languages section, you can extend language support by adding custom languages not included by default.
To add a custom language, follow these steps:
  1. Click Add Language in the upper-right corner.
  2. Specify a language name and choose the main language if a custom language is a dialect.
  3. Define and fill in language codes.
  4. Set text direction and select plural form.
  5. Click Create.
Once added, custom language codes will be automatically applied to the corresponding placeholders whenever used. You can also create custom codes for your custom languages using Language Mapping.
Create the Fields to add additional helpful information, links, or data to various entities like your projects, user accounts, tasks, and more.
Read more about Fields.
Create custom placeholders using supported Expression Syntax Elements, which you can assign to preferred projects.
Read more about Custom Placeholders.
Enable Permission Granularity Mode to manage project groups as separate units inside one Crowdin Enterprise account. You can then add projects to specific groups or subgroups. This mode allows working with workflow templates, translation memories, glossaries, and machine translations for each project group separately. When you assign group managers, they will have access to all project resources except the Settings and Managers sections.
Create an OAuth app that can be used to make authorized requests to the Crowdin Enterprise API or as a Single Sign-On service. You can build custom integrations and give them access to use your account on your behalf. Only organization admins will be able to modify its credentials or delete an OAuth app to revoke its access.
Some of the most common uses for this functionality include:
  • OAuth apps let you make authorized requests to API.
  • OAuth apps are often used as a Single Sign-On service. You can allow users to sign in your service with their Crowdin Enterprise accounts.
See the Authorizing OAuth Apps to learn how to authorize OAuth apps to access your Crowdin account.
To add an OAuth app, follow these steps:
  1. Click on your profile picture in the upper-right corner and select Organization Settings.
  2. Switch to the OAuth apps section on the left sidebar and click New App.
  3. On the Create application page, enter the following information:
    • Application name and Application description (optional) will be shown to users when they authorize the app with access to their Crowdin Enterprise accounts.
    • Authorization callback URLs are the URLs where users will be sent after they authorize with Crowdin Enterprise. You can add multiple URLs separated by a comma (no need to use quotation marks).
    • Confidential is selected by default. Keep it selected when a trusted backend can store the client secret. Clear it for single-page (SPA), mobile, and CLI apps, which authorize with PKCE and have no client secret.
    • Select the access your app requires from the list of Scopes available.
  4. Click Create Application.
After creating an OAuth application, organization admins can make changes to it. Go to Organization Settings > OAuth apps to see the list of OAuth apps added for your organization.
To find a specific application, type its name or Client ID in the search field at the top of the list.
Click the necessary app, or click Edit in its row, to be able to:
  • Update the application name, description, URLs, scopes, and client type.
  • Delete the application.
  • Check how many organization users are using the app.
  • Check the client type: Confidential or Public (PKCE, no secret).
  • Access Client ID and Client Secret of the created application.
  • Reset Client Secret for the app.
  • Revoke all user tokens.
Switching an application between confidential and public changes how it authorizes, so Crowdin Enterprise asks you to confirm. Making an application public permanently deletes its client secret and switches it to PKCE. Making it confidential generates a new client secret. In both cases, all active tokens are revoked, so users must authorize the application again.
OAuth applications used by a Crowdin App authorize with a client secret, so their client type stays confidential.
Track important events that happen on the organizational level. Security log includes events such as logins, passwords, usernames, and email changes, etc. Click on the needed event to see the following details: Event type, Location, IP, Device, and Date. Use filters to find specific event types and users.
Monitor and audit API activities within your organization using the API Log. This section provides a detailed record of API actions, categorized by results (Successful, Unsuccessful) and action types (e.g., Storages, Languages, Projects and Groups, etc.). The table includes columns for Date, Action, Response, and IP, offering useful insights when reviewing API activities. Use the search and filter options to quickly locate specific events and ensure transparency in API usage.
View information about Crowdin’s policies, terms of service, and compliance standards, as well as Crowdin’s commitment to data security and privacy.
You can transfer ownership or delete your organization from Crowdin Enterprise. Before deleting, you can export some of your organization’s data, including invoices.
The organization ownership transfer action facilitates the seamless transition of administrative control from one user to another within the organization. This process includes initiating the transfer, designating a new owner, executing the transfer, and providing retained administrative access for the former owner. The subscription stays linked to the organization, so it continues as usual after the transfer.
Before you transfer ownership:
  • Grant admin access to the user you want to assign ownership to.
Deleting organization is permanent. It removes all the info associated with this organization. This means all the projects, organization accounts, localization resources, and other related data become irretrievable.
Before you delete the organization:
  • Consider exporting your organization data (including TMs, glossaries, workflow templates).
  • Download the invoices and transaction history for each subscription.
