Machine Translation
Translate in CrowdinMachine translation engines integrated with Crowdin Enterprise provide translation suggestions from services like Google Translate and AutoML Translation, Microsoft Translator, and others.
MT suggestions are displayed in the Editor’s Automated Suggestions section in the order of the engines’ configuration dates. To prioritize a specific engine’s suggestions, configure that engine first.
Also, you can perform Auto-Translation using MT engines.
By default, machine translations are enabled for each project, but it is required to configure the translation engines before the project members can use them. If you want to disable this option for specific projects, clear Show machine translation suggestions in Project Settings.
To configure the machine translation engines, follow these steps:
- Open your organization’s Workspace and select Machine translation on the left sidebar.
- At the bottom right, click Add MT Engine.
- In the appeared dialog, select an engine from the Engine drop-down list.
- (Optional) Edit the Name of the MT engine.
- Enter the requested credentials.
- (Optional) In the Applicable languages field, select the languages for which the MT engine should provide translations. Alternatively, leave empty for access to all languages.
- (Optional) In the Enable in selected project field, select the projects in which you want to use the MT engine. Alternatively, leave empty to enable it for all organization projects.
- Click Create.
Crowdin Translate is Crowdin’s own machine translation engine, so it works without an API key or a third-party account.
When configuring Crowdin Translate, you can adjust the following setting:
- Multiple Translations: Generates four translation suggestions for each string instead of one.
Go to Windows Azure to access your Microsoft Translator API subscription key. Translator Text API offers a free tier with 2,000,000 translated characters.
When configuring the Microsoft Translator, you can adjust the following settings:
- Model: Produces translations with your own Microsoft Translator model instead of the general one. Enter the model identifier.
- Resource location: Sets the region associated with your API key. Specify it when the location is other than
global.
DeepL API is accessible with the DeepL API plans, which are separate from the DeepL Translator plans for the web and desktop apps. Navigate to your DeepL account to get your API key.
When configuring the DeepL Translator, you can adjust the following settings:
- Tone per language: Sets a formal or informal tone for specific target languages. In each row, select Formal or Informal under Tone and the target languages under Languages. To assign the other tone to more languages, click Add tone and fill in the new row. The Languages list includes only the languages for which DeepL supports a tone. Languages without an assigned tone use DeepL’s default tone.
- Model type: Selects the DeepL models used for translation. Latency optimized is the fastest. Prefer quality optimized and Quality optimized use next-generation models, which are slower and cover fewer languages. For a language pair those models do not cover, you still get a translation from the classic models.
- Tag handling: Defines how DeepL processes markup in the source text. Select XML or HTML to match your source files. Read more about Inline Tags and Machine Translation.
- Tag handling version: Controls how DeepL positions tags in the translation. Version 2 improves tag placement.
- Use context: Sends additional context, such as the file or string context, to DeepL to improve translations of short texts like product names, article headlines, or UI elements.
- Style rules: Applies a writing style defined in your DeepL account. Works only when the target language matches the language of the style rule.
- Translation memories: Reuses previously approved translations from a DeepL translation memory for matching segments.
- Translation memory match threshold (%): Sets the minimum match percentage a segment must reach to be reused, from 0 to 100. Defaults to 75.
- Custom instructions: Steers the translation with your own guidance, for example Keep brand names untranslated. Enter one instruction per line, up to 10 instructions of 300 characters each. Applies to these target languages: German, English, Spanish, French, Italian, Japanese, Korean, and Chinese.
The DeepL Translator can use glossaries, style rules, and translation memories from your connected DeepL account to keep your terminology and translations consistent. In Crowdin Enterprise, you can configure several resources of each type and assign specific languages or language pairs to each one.
To configure a DeepL resource, follow these steps:
- Select a glossary, style rule, or translation memory from the respective drop-down menu. These lists are automatically populated from your connected DeepL account.
- In the Language pairs drop-down menu below it, select the language pairs the chosen resource should apply to.
- (Optional) To configure another resource of the same type, click Add glossary, Add style rule, or Add translation memory and repeat the steps above. To remove a resource configuration, click .
- Click Create.
ModernMT Real time translation API is accessible with the Real time or Human-in-the-loop subscription plans. Navigate to the ModernMT Dashboard to get your License key. If you’re subscribed to a different subscription plan, you can switch to the Real time or Human-in-the-loop plan via the Manage Plan page.
The free version of Amazon Translate is available for 12 months. Afterward, you will need to pay for the number of characters translated. Crowdin uses Standard Text Translation type provided by Amazon Translate. Read more about available Amazon Translate pricing options.
Read more about obtaining your access key needed for Amazon Translate integration.
When configuring Amazon Translate, you can adjust the following settings:
- Region: Sets the region of your Amazon Translate resources (for example,
us-east-2). Specify it first to load your terminologies. - Terminologies: Applies your custom terminology to the translations. Select a terminology, then select the Languages it applies to. To configure another terminology, click .
What are the minimal scopes for an IAM user required to set up Amazon Translate to be used in Crowdin Enterprise?
The minimal IAM scopes required depend on whether you’re using terminologies or not:
Without terminologies:
{ "Version": "2012-10-17", "Statement": [ { "Effect": "Allow", "Action": "translate:TranslateText", "Resource": "*" } ]}With terminologies:
{ "Version": "2012-10-17", "Statement": [ { "Effect": "Allow", "Action": [ "translate:TranslateText", "translate:GetTerminology", "translate:ListTerminologies" ], "Resource": "*" } ]}Alternatively, you can use the AWS managed policy: TranslateReadOnly, which provides the necessary read-only access to Amazon Translate.
To use Google Translate, you shall have a Google Cloud account with an active billing profile. Cloud Translation is priced monthly based on usage. Learn more.
To obtain the API key necessary for integration, follow these steps:
- Go to Google Cloud Console. Log in to the existing Google Cloud account or set up a new one.
- Select an existing project or add a project using the New Project.
- Go to API & Services > Library and search for Cloud Translation API.
- Click Enable.
- Go to API & Services > Credentials and click Create credentials > API key.
- Copy the API key and click Close.
To use AutoML Translation, you shall have a Google Cloud account with an active billing profile. Google AutoML Translation is priced monthly based on how many characters you send for translation. Learn more.
To create a service account key and obtain the necessary credentials for integration, follow these steps:
- Go to API & Services > Library and search for Cloud AutoML API.
- Click Enable.
- The next step is to create a service account private key pair. The service account is used by Crowdin. Applications use service accounts to make authorized API calls.
To set up authentication and create your private key, follow these steps:
- Go to API & Services > Credentials.
- Click Create credentials > Service account.
- In the Service account name field, enter a name that describes what this service account will do.
- Click Create and continue.
- From the Role list, select Project > Cloud Translation API Editor and click Continue.
- Click Done.
- In the API & Services > Credentials, click on the created service account.
- Switch to the Keys tab.
- Click Add key > Create new key.
- Select JSON and click Create. A JSON file that contains your key will be downloaded to your computer.
Google Cloud AutoML Custom Glossary Configuration
Section titled “Google Cloud AutoML Custom Glossary Configuration”Google Cloud AutoML custom glossary allows you to translate your domain-specific terminology consistently. You can use only one Google Cloud AutoML custom model at once. If you have multiple custom models you’d like to use in your Crowdin Enterprise projects, create multiple instances of Google Cloud AutoML MT engine under your Crowdin Enterprise account, specifying the different models in the settings of each MT engine. During the auto-translation via MT, you can alternately use Google Cloud AutoML with the needed model.
To configure your Google Cloud AutoML custom glossary, follow these steps:
- In the appeared dialog, select Google AutoML Translate from the Engine drop-down list.
- Click Select file and upload your JSON credentials.
- (Optional) Specify your Resource location (e.g., us-central1). The Custom model and Glossary drop-down lists are populated once your credentials and resource location are in place.
- (Optional) Select your Custom model.
- (Optional) Select your Glossary from the respective drop-down list.
- (Optional) Map the Custom model language to the corresponding Crowdin Language.
- (Optional) Select applicable languages. Alternatively, leave empty for access to all languages.
- (Optional) Select projects in which you want to use the MT engine. Alternatively, leave empty to enable it for all organization projects.
- Click Create.
Once you specify your MT engine credentials, the system automatically assigns a unique MT engine ID. Later on, you can use these IDs in API requests for auto-translation via machine engines.
You can find the MT engine ID in the organization’s Workspace > Machine translation page. Alternatively, you can also get your MT engine IDs via API.
Depending on your HTML Tags Displaying setting and the file format, the Editor may show inline tags in a simplified, numbered form (for example, <0>Sample</0> instead of <a href="https://sample.com">Sample</a>). This is only a display option in the Editor. It is not the form that Crowdin Enterprise passes to the machine translation engine.
When a string is machine-translated, Crowdin Enterprise works with the inline markup from your original source file rather than the simplified tags shown in the Editor. Machine translation engines differ in how they handle this markup: some reposition the tags within the translated segment, and their placement can differ from one engine to another. This can also affect the overall translation quality.
If tags in an MT suggestion appear in an unexpected order or position, this usually reflects how the selected engine handles inline markup rather than a Crowdin Enterprise setting.
When MT engines are updated with new features or models, cached translations in Crowdin Enterprise may no longer reflect the latest translation capabilities. To display updated translations in the Editor’s Automated Suggestions section, clear the MT engine cache. This can be especially useful if you’ve already viewed certain strings in the Editor, as Crowdin Enterprise stores cached MT suggestions for those strings.
A cached MT suggestion is marked with a history icon on the engine’s logo in the Editor. Hover over the icon to see when it was last refreshed (for example, Last updated: 7 hours ago).
To clear the cache for your configured MT engine, follow these steps:
- Click (or right-click) on the needed MT engine in the list.
- Click Clear cache.
Alternatively, open the needed MT engine for editing and click Clear cache at the bottom right of the panel.
If you need to pause or stop using any of the configured MT engines, follow these steps:
- Click (or right-click) on the needed MT engine and select Edit.
- Turn off the MT is enabled toggle.
- Click Update.
The engine stays in the list with its credentials in place, so you can turn the MT is enabled toggle back on at any time to start using the engine again.
