You can currently connect Google Translate and AutoML Translation, Microsoft Translator, DeepL Pro, Amazon Translate, and Watson (IBM) Language Translator engines.
Additionally, you can add more machine translation engines by installing respective applications from the Crowdin Marketplace.
To connect the MT engine, follow these steps:
Go to the Windows Azure to access your Microsoft Translator API subscription key. Translator Text API offers a free tier with 2,000,000 translated characters.
How to sign up for the Microsoft Translator Text API.
DeepL API is accessible only with the DeepL API Free and Pro subscription plans (For developers tab). Navigate to the DeepL Pro Account page to get a unique Authentication Key. Please note that the DeepL API plan is the only plan that provides this feature.
In case you’re subscribed to a different subscription plan, you can switch to the DeepL API plan in your personal account settings. DeepL also provides a simulator that allows you to check your Authentication Key in action.
Watson (IBM) Translator offers 1,000,000 characters per month free of charge and paid plans to select from after exceeding the limit. Go to the Watson (IBM) Services Console to get your Watson Translator API key.
ModernMT Real time translation API is accessible with the Real time or Human-in-the-loop subscription plans. Navigate to the ModernMT Dashboard to get your License key. In case you’re subscribed to a different subscription plan, you can switch to the Real time or Human-in-the-loop plan via the Manage Plan page.
The free version of Amazon Translate is available for 12 months. Afterward, you will need to pay for the number of characters translated. Crowdin Enterprise uses Standard Text Translation type provided by Amazon Translate. Read more about available Amazon Translate pricing options.
Read more about obtaining your access key needed for Amazon Translate integration.
To use your Custom Terminology, follow these steps:
To use Google Translate, you shall have a Google Cloud account with an active billing profile. Cloud Translation розраховується щомісячно залежно від використання. Дізнатися більше
To obtain the API key necessary for integration, follow these steps:
To use AutoML Translation, you shall have a Google Cloud account with an active billing profile. Google AutoML Translation розраховує платіж щомісяця залежно від кількості символів, які ви відправляєте для перекладу. Learn more
To create a service account key and obtain the necessary credentials for integration, follow these steps:
Щоб налагодити аутентифікацію і створити свій особистий ключ, виконайте наступні дії:
Google Cloud AutoML custom glossary allows you to translate your domain-specific terminology consistently. You can use only one Google Cloud AutoML custom model at once. If you have multiple custom models you’d like to use in your Crowdin Enterprise projects, create multiple instances of Google Cloud AutoML MT engine under your Crowdin Enterprise account, specifying the different models in the settings of each MT engine. During the pre-translation via MT, you can alternately use Google Cloud AutoML with the needed model.
To configure your Google Cloud AutoML custom glossary, follow these steps:
