IP Addresses and Domains
When you work with private integrations (e.g., integrations with self-hosted VCS) or use a firewall for your company network, you need to add dedicated Crowdin IP addresses and domains to the allowlist to ensure that it operates properly while staying secure. A similar approach is applicable when using Crowdin webhooks.
Crowdin uses the following IP address to interact with the integrations:
52.45.158.111/32Crowdin uses the following IP addresses to send webhooks and interact with AI providers and MT engines:
3.88.119.237/323.224.117.103/323.255.22.171/3213.223.127.35/3218.204.99.167/3234.232.97.56/3235.171.66.7/3244.194.158.59/3244.196.180.134/3244.215.240.56/3252.6.250.28/3252.55.92.57/3252.72.249.65/3252.73.138.157/3252.86.187.19/3254.85.180.8/3254.164.39.118/3254.235.202.61/32For your convenience, you can get the current IP addresses in JSON format.
Crowdin uses the following domains to provide its services from:
accounts.crowdin.comcrowdin.comapi.crowdin.comcrowdin-assets.cf-downloads.crowdin.comcrowdin-importer.cf-downloads.crowdin.comcrowdin-packages.cf-downloads.crowdin.comcrowdin-screenshots.cf-downloads.crowdin.comcrowdin-static.cf-downloads.crowdin.comcrowdin-tmp.cf-downloads.crowdin.comstatics.crowdin.netdistributions.crowdin.netbadges.crowdin.netws-lb.crowdin.comcdn.crowdin.comd2srrzh48sp2nh.cloudfront.netenterprise.crowdin.comenterprise-statics.crowdin.net<organization_domain>.crowdin.com<organization_domain>.api.crowdin.comproduction-enterprise-assets.cf-downloads.crowdin.comproduction-enterprise-importer.cf-downloads.crowdin.comproduction-enterprise-packages.cf-downloads.crowdin.comproduction-enterprise-screenshots.cf-downloads.crowdin.comproduction-enterprise-static.cf-downloads.crowdin.comproduction-enterprise-tmp.cf-downloads.crowdin.comenterprise-euw1-statics.crowdin.netbadges-euw1.crowdin.netenterprise-euw1.crowdin.comproduction-euw1-enterprise-assets.cf-downloads.crowdin.comproduction-euw1-enterprise-importer.cf-downloads.crowdin.comproduction-euw1-enterprise-packages.cf-downloads.crowdin.comproduction-euw1-enterprise-screenshots.cf-downloads.crowdin.comproduction-euw1-enterprise-static.cf-downloads.crowdin.comproduction-euw1-enterprise-tmp.cf-downloads.crowdin.com Thank you for your feedback!
