İçeriğe geç
Project Reports
Bu içerik henüz dilinizde mevcut değil.
Crowdin’de Çevirin
To view your project status, assess the effectiveness of auto-translation methods, estimate and count the translation cost, keep track of the most active members, and view historical data of previously generated reports, open your project and go to the Reports tab.
To add more reports, the project owner can click next to the report tabs and install a report app from the Store. Installed report apps appear as separate tabs for the members and projects set in the app’s permissions.
Use this section to get a comprehensive summary of your project’s health, monitor key activities, and track progress over selected time periods. In the upper-right corner, you can select a report unit (words, strings, characters, or characters with spaces) that will apply to all reports in this section. The comparisons shown in percentage are counted by comparing the chosen period of time to the same previous period of time (e.g., if you select a month, the current month is compared to the previous one).
The top of the page displays the primary statistics for your project’s volume:
The Translatable and Hidden values include duplicate strings, and each shows how much of its text is in duplicates.
Below the main statistics, the Overview section contains the following reports:
This report tracks the overall translation and proofreading activity in the project. You can filter the data by Date Range, Language, and Member. The report is split into two main parts: Translation and Proofreading.
  • Total (end of period)
  • Human Translation
  • Translation Memory
  • Machine Translation
  • AI
Use this report to review the savings achieved by using Translation Memory (TM), Machine Translation (MT), and Artificial Intelligence (AI).
You can filter the data by Date Range, Language, Member, and Files or Branches depending on the project type. Clicking the Files/Branches filter opens a dialog with two options: All files/branches (selected by default) and Selected files/branches. When you choose Selected files/branches, a file tree appears in the dialog where you can browse and adjust your selection, then click Save to confirm. The report uses a Rates template to calculate savings. By default, it uses the Default Net Rate Scheme, but you can select a custom template to reflect specific agreements.
Using the Mode dropdown, you can switch between viewing the data as % (percentage) or currency.
The Translation Savings section displays the Total savings as a percentage or in currency for the selected period, along with a breakdown of savings from Translation Memory, Machine Translation, and AI.
The bar chart below visualizes these savings over time. Savings are calculated for each string only once, upon the first manual contribution (a new translation or an approval). This also includes approving a translation that originated from an Auto-translation (in this case, the saving is attributed to the date and method of the auto-translation).
If a string has a combination of TM and MT/AI suggestions available, the new contribution is counted towards the category with the highest potential saving value.
Hovering over the bars provides detailed information on savings per method on a daily or monthly basis. For a more granular view, you can also expand the Breakdown by Language section to see a table of savings for each specific language.
The Default Net Rate Scheme is the standard, built-in template used for calculation if no custom template is selected. This scheme defines savings based on a tiered “Net Rate” model, which reflects industry standards where not all matches provide equal value.
For example, a low-percentage fuzzy match (e.g., below 75%) is often reworked entirely by a translator. Therefore, this scheme considers such matches to provide 0% savings, even though a match was suggested.
The default scheme is divided into two categories, each with its own rates:
Saving Rates: TM
Match TypeNet RateSaving
Perfect Match / Approval Without Changes5%95%
100% / Approval Without Changes15%85%
95-99% Fuzzy Match35%65%
85-94% Fuzzy Match55%45%
75-84% Fuzzy Match75%25%
< 75% Fuzzy Match100%0%
Saving Rates: MT / AI
Approval Without Changes10%90%
99-90%30%70%
89-70%50%50%
69-50%75%25%
< 50%100%0%
Here are a few examples of how savings are calculated based on these default rates:
  • TM Example: A 10-word string is translated using a 95-99% Fuzzy Match from your TM. According to the table, this match type has a saving of 65%. Therefore, the report will count 6.5 words (10 words * 65%) as saved.
  • MT/AI Example (Approval): A 10-word string is auto-translated by an MT engine. A proofreader reviews and approves it without making any changes. This action falls into the Approval Without Changes category, which has a saving of 90%. The report will count 9 words (10 words * 90%) as saved.
  • MT/AI Example (Manual Edit): A 10-word string has an MT suggestion. A translator edits the suggestion (or writes their own translation). The system compares the translator’s final saved translation to the original MT suggestion and finds they are 80% similar. This action falls into the 89-70% match category, which has a saving of 50%. The report will count 5 words (10 words * 50%) as saved.
  • No Savings Example: A 10-word string has a < 75% Fuzzy Match. According to the TM table, this provides 0% saving. Even though there was a match, it’s not counted as a saving in the report, as it likely required a full re-translation.
This report tracks changes made to the source content over a selected time frame. You can filter the data by Date Range. The report displays the Total (end of period) volume of text, along with specific metrics for content that has been Added, Deleted, or Modified.
The bar graph helps you visualize when the most significant content updates occurred. By hovering over the bars, you can see the specific changes that occurred each day or month.
This report provides insights into the automated Quality Assurance (QA) checks, highlighting potential inconsistencies in translations. You can filter the data by Date Range and Language.
Key metrics include:
  • New (Period): The number of new QA issues found within the selected period.
  • Total (end of period): The total number of unresolved QA issues at the end of the selected period.
  • Per 1000 words: The density of QA issues relative to the word count. This metric includes approved content and is only shown if the total word count is greater than 1000.
  • Content with Issues: The volume of text that contains QA issues, including approved content.
  • Content with Issues Rate: The percentage of text that has QA issues, including approved content.
Below the metrics, the report also features several additional components:
  • Breakdown by Language: An expandable section that shows a table of the key metrics broken down by each target language.
  • Issues Trend: A line graph that monitors the total number of QA issues over time. You can hover over data points to see the total number of issues for a specific day.
  • Issues by languages: A heatmap-style table that visualizes the distribution of QA issue types (e.g., Spelling mistakes, Consistent terminology) across all target languages. You can hover over a cell to see the precise number of issues for that specific language and type.
This report tracks issues manually created by project members to report problems or ask questions. You can filter the data by Date Range and Issue Type. The main metrics show the Total, Created, and Resolved issues, each with a comparison to the previous period.
This report consists of the following components:
  • Issues by Type: A table showing the total, created, and resolved counts for each issue category (e.g., General question, Current translation is wrong).
  • Incorrect Translations by Language: A table focusing on the Current translation is wrong issue type, breaking down the numbers by language.
  • Cumulative Created vs Resolved Issues: A line graph that visualizes the cumulative number of created versus resolved issues.
  • Average Resolution Time by Issue Type: A bar chart showing the average time in days it takes to resolve each type of issue.
  • Top Reporters & Resolvers: A leaderboard of members who have reported and resolved the most issues, with sortable columns for Name, Issues Reported, and Issues Resolved.
This report helps you monitor the activity and changes among your project members, which can help managers assess the level of engagement. You can filter the data by Date Range. The report displays key metrics about your member base for the selected period, including:
  • Total (end of period): The total number of members in the project.
  • Active: The number of members who were active during the period.
  • New: The number of newly joined members.
  • Pending (end of period): The number of users with pending join requests (including both incoming and outgoing invitations).
  • Blocked (end of period): The number of blocked members.
A graph below the metrics displays the trend of the total member count over time.
Use this report to plan your budget and count the approximate cost of translations. Set the translation and approval rates to see the cost for untranslated and not approved strings in the project.
  • Task: Not selected, All tasks, or multiple specific tasks.
  • Strings Added: Today, Last 7 days, Last 30 days, This month, All time, or Custom range.
  • Files: All or specific files.
  • Labels (Specific to projects with labels): Not selected, Strings with selected labels, or Strings without selected labels.
  • Language: All languages or a specific target language.
  1. Select the preferred currency and the report unit (words, strings, characters without spaces, or characters with spaces).
  2. Set your rates for translations and approvals.
  4. Click Generate.
Generating Cost Estimate
After you click Generate, the Cost Estimate report is added to a queue and processed in the background. This ensures that multiple reports generated by different users or with different filters don’t override one another. Each report is generated separately and appears in the Reports > Archive section once completed.
  • Full translation – for each untranslated string.
  • Proofread – for each string that isn’t approved yet.
Adding TM Match Type
In addition to base rates that are applied to all languages by default, you can add custom rates for specific languages. To add custom rates, click Add custom rates.
To select the language or languages for custom rates, click Edit Languages and select the ones you need. You can create as many custom rates as you need.
Adding Custom Rates
If you plan to work with multiple rate configurations, save them as templates by clicking Save as > New rates template, then specify the template name and click Save.
When saving a new template you can choose the template visibility using the following options:
  • Share with all project members – makes the template visible to all translators within the project. Regardless of the number of translators or their different rates, they all will have access to the template. It can include both general rates and custom rates for specific languages and translators, along with a net rate scheme. This transparency promotes clarity in pricing, allowing translators to review rates, generate reports on their translations, and calculate cost estimates. The key benefit is that translators understand the net rate scheme and can apply their base rate, even if it’s not included in the template.
  • Share with managers within the owner’s projects – makes the template global, visible only to managers across all projects of an owner. This option streamlines rate consistency across various projects.
If neither of the options is selected, the template remains visible only to managers within the current project, limiting access to a select group of project members. These options provide flexibility in controlling who can view and use the rate template to accommodate different organizational preferences.
Saved templates allows you to quickly switch between different configurations for report generation.
Click Templates to view and manage your saved rate templates.
In the Advanced settings section, select Include auto-translated strings if you want a Cost Estimate report to also count strings for translation when they were only auto-translated (via TM, MT, or AI) and aren’t approved yet. By default, this option is cleared.
For example, you have an untranslated string Validate your username in your project, and a Cost Estimate report counts it for translation. Then you auto-translate this string via TM or MT. With Include auto-translated strings cleared, the next Cost Estimate report no longer counts this string for translation. With the option selected, the report keeps counting it for translation as long as the string has no approved translation and no translation added by a person.
To include fuzzy (99% and less) internal matches, as well as perfect (101%) and 100% matches, in your Cost Estimate report and get a more comprehensive prediction of how many strings can be added to the TM if translated in sequence, select Calculate Internal Fuzzy Matches in the Advanced settings section. Note that these calculations are approximate because the actual translation order may differ.
When the Cost Estimate report is generated, it displays the following details:
  • Total - General cost estimate for all languages (including translation, proofreading, and any TM savings).
  • Subtotals - Cost estimate for each target language:
    • TM savings – Savings from existing translations (in TM or within the project).
Each row in the main table represents a match category or status:
  • Total – Summarizes all untranslated strings, words, and characters, as well as the weighted units after match discounts and percentage of the total.
  • TM Match (total) – Untranslated strings matching entries in Translation Memory, often split into:
    • 101% (Perfect match) – Exact text and context match.
    • 100% – Exact text match, but context differs.
  • Repetitions (total) or Internal Match (total) – Untranslated strings matching other strings within the project. Displaying depends on whether Calculate Internal Fuzzy Matches is enabled. Subcategories (for example, 101%, 100%, and fuzzy) depend on your Net Rate Schemes. Each subcategory row carries the internal label when Calculate Internal Fuzzy Matches is enabled, and the repetition label otherwise.
    If an untranslated string has both a 101% TM match and a 100% internal match, it counts toward TM match.
  • No Match – Strings with no TM or internal matches, requiring translation from scratch.
  • Not Approved – Translated strings that are still awaiting approval.
  • Strings, Words, Characters without spaces, Characters with spaces – Basic volume metrics.
  • Weighted Words / Strings / Characters / Characters with Spaces – Shows the adjusted metric after factoring in repetitions and fuzzy matches, reflecting the actual translation effort.
  • % – Share of weighted units in each category.
After the main table, each language subtotal also includes a table that shows, for each folder or file, how many strings fall under Untranslated, No Match, TM Match, Internal Match (Repetitions when Calculate Internal Fuzzy Matches is cleared), and Not Approved. This helps identify where to focus your translation efforts and budget.
To download the Cost Estimate report, click Export and select the preferred format (CSV, XLSX, or JSON) for further analysis or record-keeping.
Use this report to calculate the actual translation and proofreading costs based on the volume of units completed by contributors (e.g., words).
You can generate a Translation Cost report based on the following filter parameters:
  • Task: Not selected, All Tasks, or multiple specific tasks.
  • Date Range: Today, Yesterday, Last 7 days, Last 30 days, This month, Last month, All time, or Custom range.
  • Branches (Specific to string-based projects): All branches or Selected branches.
  • Member: All or specific users.
  • Group by: Member or language.
To generate the Translation Cost report, follow these steps:
  2. Set your rates.
  4. Click Generate.
Generating Translation Cost
When setting up the report, you can also expand Advanced settings to adjust how the report is calculated. By default, the generated report is saved to the Archive. To skip saving it, clear Save to archive.
You can set the prices for Base rates and configure Net Rate Schemes (percentage of the full translation rate paid for translation and proofreading based on TM Match, MT Match, AI Match, and Other translations).
In the Base Rates section, you can set the rate for the following type of work:
Click Advanced settings to expand a section with additional configuration options for your report:
  • Use category-based proofread rates (enabled by default): Treats each approval as an identical translation at the 100% match rate of its Net Rate Scheme category (TM, MT, AI, or Other). When disabled, all approvals use the flat Proofread base rate.
  • Exclude approvals for edited translations (enabled by default): Skips an approval when the same user already translated the string, so their work isn’t counted twice. When disabled, both the translation and the approval are counted.
  • Use Specific Categories for Auto-Translations (enabled by default): Assigns auto-translation matches to their source category (MT, AI) instead of the default Other translations category. Post-editing MT or AI output usually takes a different effort than editing human translations, so this measures cost more precisely.
  • Use edit distance for TM Net Rate Scheme (disabled by default): Categorizes TM matches by how much the suggestion was edited to reach the final translation instead of by source similarity, which better reflects post-editing effort. Enabling it removes the 101 (perfect) match type and caps TM matches at 100. Matches recorded before July 13, 2026, fall back to source similarity, but because the option removes the 101 (perfect) match type, any perfect matches among them are also counted as 100.
In the Net Rate Schemes section, you can set the percentage of the full translation rate to be paid for translations and their approvals based on various Match types.
Because the Use category-based proofread rates option is enabled by default, the cost of proofreading depends on the translation’s origin category (TM, MT, AI, or Other).
Regardless of the translation’s original match percentage, its approval is always calculated at the maximum match rate for that category.
Here is how it works in practice:
  • Partial matches: If a translation was an 85% MT match, its approval is charged at the 100 / Approval rate under the MT Match category.
  • Translations from scratch (No match): If a translation was made without any suggestions, its approval is charged at the 100 / Approval rate under the Other translations category.
By default, you can configure the percentage of the full translation rate for the following categories:
TM Match:
  • 101 (perfect) / Approval – for translations made using Perfect match TM suggestions (source strings are identical to the TM suggestion by text and context), and for their approvals. This match type is available only when Use edit distance for TM Net Rate Scheme is disabled.
  • 100 / Approval – for translations made using 100% match TM suggestions (source strings are identical to the TM suggestion only by text), and for approvals of all TM matches of 100% or lower.
MT Match:
  • 100 / Approval – for translations made using 100% match MT suggestions (the saved translation matches the MT suggestion exactly), and for all approvals within the MT category.
AI Match:
  • 100 / Approval – for translations made using 100% match AI suggestions (the saved translation matches the AI suggestion exactly), and for all approvals within the AI category.
Other translations:
  • 100 / Approval – for translations made using existing translations from other users (the saved translation matches the existing translation exactly), and for approvals of translations made from scratch (No match) or using existing translations.
If multiple scheme categories can be applied to a translation (e.g., a string has a combination of TM, MT, or AI suggestions, and existing translations from other users), the new translation is calculated at the lowest Net Rate Scheme value. For example, if a string has a 101% (perfect) TM match suggestion (10% of the full translation rate) and a 100% MT match suggestion (5% of the full translation rate), the new translation added to this string will be calculated at 5% of the full translation rate.
You can also add custom match types for the TM, MT, AI, and Other translations categories, specifying the preferred percentage of text similarity and the percentage of the full translation rate to be paid for such a translation.
  1. Click in the header of the specific category section.
  2. Click at the bottom of the section.
  4. Click again to save the settings.
In addition to base rates that are applied to all languages and users by default, you can add custom rates for specific languages and users. To add custom rates, click Add custom rates.
To select the languages and users for custom rates, click Edit Languages and Edit Users and select the ones you need. You can create as many custom rates as you need.
Adding Custom Rates
When the Translation Cost report is generated, it displays a comprehensive breakdown of costs, savings, and work types.
  • Total – The final calculated translation and validation cost (including TM, MT, and AI savings, weighted units, and auto-translated units).
  • User and Language Totals – Below the main summary, the report splits data based on your selected Group by filter:
    • Group by Member – Shows the total cost incurred by each individual translator or proofreader, with language subtotals nested underneath.
    • Group by Language – Shows the total cost for each target language, with individual translator or proofreader subtotals nested underneath.
  • Subtotals – Detailed metrics provided for each target language or user block:
    • Translated & Post-edited – The cost of translations.
    • Proofreading – The cost of approvals.
    • Savings (TM, MT and AI) – The financial amount saved by leveraging matches from TM, MT, or AI.
    • Weighted Words / Strings / Characters / Characters with Spaces – The adjusted unit count after applying repetition and fuzzy match discount schemes, reflecting the actual translation effort.
    • Auto-translated Words / Strings / Characters / Characters with Spaces – The total number of units that were already populated via auto-translation.
Within each user or language section, the report generates a breakdown table containing the following columns:
  • Match type – The specific category and percentage range applied to the text.
  • Contributed Words / Strings / Characters / Characters with Spaces – The raw number of units handled within that specific row type.
  • Weighted Words / Strings / Characters / Characters with Spaces – The adjusted unit volume based on your Net Rate Scheme rules.
  • Rate per unit – The specific price paid per single unit for that match or approval type.
  • Price – The total cost for that row, calculated based on the unit count and assigned rate.
By default, with Use category-based proofread rates enabled, all translations and approvals are grouped together by their origin category. A separate proofreading table is not shown; instead, approvals appear as rows within the respective match blocks:
  • No match – Units translated from scratch with no leverage from TM, MT, or AI (calculated at the full translation rate).
  • TM Match – Units matched against the Translation Memory. This includes distinct rows for translations (e.g., 101% (perfect), 100%, 99-85%) and their respective approvals (e.g., Approval 101% (perfect), Approval 100%).
  • MT Match – Units matched against Machine Translation engines. Includes rows for translations (e.g., 100%, 99-94%) and a dedicated Approval row for validations within this category.
  • AI Match – Units matched against AI suggestions. Includes rows for translations (e.g., 100%, 99-94%) and a dedicated Approval row for validations within this category.
  • Other translations match – Units matched against existing translations from other users. Includes rows for translations (e.g., 100%, 99-94%) and a dedicated Approval row for validations within this category.
  • Total – Summarizes all translated, weighted, and approved units for that specific section.
To download the Translation Cost report for offline analysis or accounting, click Export and select your preferred format (CSV, XLSX, or JSON).
Use this report to evaluate the translation quality of auto-translation methods (AI, MT, and TM) used in your project and identify the most efficient ones.
This report analyzes the post-editing effort required for auto-translated strings. It compares the initial auto-translation against the final approved translation to calculate a Match Score. This helps you identify which AI prompts or MT engines require the least amount of human editing, allowing you to adjust your workflow and increase the usage of the best-performing methods.
The Match Score metric is calculated at the character level. The report unit you select (Strings, Words, Characters, or Characters with spaces) determines how the results are displayed (e.g., if you select Strings, the entire source string is placed in a category based on its total match score).
The report selects and counts strings as follows:
  • Includes only source strings that have a translation added via auto-translation which was subsequently approved.
  • The report considers auto-translations added within the selected Time period, regardless of when they were approved.
  • If a string has several auto-translations in the same language, the report counts them as one result.
To get the most actionable insights from this report, we recommend the following flow:
  1. Auto-translate – Apply auto-translation to your source content using AI, MT, or TM.
  2. Post-edit & Approve – Have your proofreaders review the auto-translated strings. They should fix any errors or stylistic issues (post-editing) and approve the final versions.
  3. Measure Accuracy – Generate the Auto-Translation Accuracy report.
  4. Optimize – Identify which AI prompt, MT engine, or TM required the least amount of human editing. Update your workflow to use that high-performing method for future translations.
You can generate an Auto-Translation Accuracy report based on the following filters:
  • Task: Not selected, All Tasks, or a specific task (available only if the project has tasks).
  • Language: All, or specific language.
  • Date range: Today, Yesterday, Last 7 days, Last 30 days, This month, Last month, All time, or Custom range. This filter selects the range of when the strings were auto-translated.
  • Files: All files or Selected files.
  • Labels: Not selected, Strings with selected labels, or Strings without selected labels (available only if the project has labels).
Additionally, using the report’s Settings, you can configure Match Score Categories. These settings determine how the graph groups translations that were edited. For example, if you set a category for 99-90%, source strings where the approved translation matches the auto-translation within that range will be grouped together. Anything below your lowest defined match category will be treated as No Match (New Translation).
To generate the Auto-Translation Accuracy report, follow these steps:
  1. Select the preferred report unit (words, strings, characters, or characters with spaces).
  2. Select the preferred way to group the histogram data (Day or Month).
    • When grouped by Day, the stacked histogram will have more bars, giving a more granular, day-by-day view.
    • When grouped by Month, the data is displayed in fewer, broader monthly segments.
  3. (Optional) Select the task if you want to generate a report based on work done within all or specific tasks. Alternatively, leave it as Not selected to generate a report based on a wider content scope.
  4. Select the preferred language.
  5. Select the Date Range.
  6. (Optional) Select Files to specify the source content. You can choose All files or Selected files.
  7. (Optional) Select Labels to filter strings based on their labels. You can choose Strings with selected labels or Strings without selected labels.
  8. (Optional) Clear Save to archive if you don’t want to save the report to the Archive.
  9. Click Settings to configure your Match Score Categories.
  10. Click Generate.
When the report is generated, you will see the information grouped into auto-translation methods (via AI, MT, and TM):
  • Auto-translation via AI:
    • Total approved words, auto-translated by AI
    • Separate graphs for each prompt (maximum 10 prompts displayed)
  • Auto-translation via MT:
    • Total approved words, auto-translated by MT
    • Separate graphs for each MT engine (maximum 10 engines displayed)
  • Auto-translation via TM:
    • Total approved words, auto-translated by TM
Each section displays the volume of source content, broken down by the following key metrics. (For this explanation, we assume Strings was selected as the report unit):
  • Total – The total number of source strings to which translations were added via auto-translation and subsequently approved. This includes strings approved without changes and strings where a proofreader added a corrected translation that was then approved.
  • 100% Match – The number of source strings where the approved translation matches the translation added via auto-translation exactly (100%).
  • Match Score Ranges (e.g., 70-99% Match) – The number of source strings where the approved translation matches the auto-translation within the configured percentage range. This indicates that a proofreader edited the auto-translation, but the final approved version remains similar to the original suggestion.
  • Avg. Match Score – The average percentage of similarity between the initial auto-translations and the final approved texts. A higher percentage means the auto-translations were accurate and required fewer edits.
  • No Match – The number of source strings where the approved translation differs from the auto-translation by more than the lowest percent in your configured match score categories. In these cases, the translation was changed so significantly during proofreading that it is treated as a complete rewrite (a new translation).
  • Quality Score – Measures overall quality based on the average match score achieved for the translated content. It is calculated as follows: ((Unedited + (Edited * Avg. Match Score)) / Total) * 100
The Stacked Histogram below the metrics visualizes the distribution of these categories over time. Each bar represents the volume of source units processed, stacked by their quality category (e.g., 100% Match, Match Score: 99-90%, No Match).
To download the Auto-Translation Accuracy report, click Export and select the preferred export format (CSV, XLSX, or JSON).
Auto-Translation Accuracy Generated
Use this report to evaluate the translation quality of individual translators in your project and identify top performers.
This report analyzes the post-editing effort required for translations submitted by human translators. It compares each translator’s initial translation against the final approved version to calculate a Match Score. This helps you identify translators who consistently produce high-quality work requiring minimal corrections, as well as those who may benefit from additional guidance or training.
The Match Score metric is calculated at the character level. The report unit you select (Strings, Words, or Characters) determines how the results are displayed (e.g., if you select Strings, the entire source string is placed in a category based on its total match score).
  • Includes only source strings that have a translation submitted by a human translator which was subsequently approved.
  • The report considers translations added within the selected Time period, regardless of when they were approved.
  • If several translators translated a string, each translator’s translation is included with its match score. If a translator added several versions of a translation, only the version closest to the approved translation is counted.
  1. Translate – Have your translators translate the project content.
  2. Proofread & Approve – Have your proofreaders review the translations. They should fix any errors or stylistic issues (post-editing) and approve the final versions.
  3. Measure Accuracy – Generate the Translator Accuracy report to see how much the proofreaders had to edit each translator’s work.
  4. Feedback – Use the findings to provide targeted feedback. Translators with high 100% Match rates are your top performers, while high No Match rates might indicate a need for better glossary adherence or style guide training.
You can generate a Translator Accuracy report based on the following filters:
  • Users: All or selected users.
  • Language: All or specific language.
  • Date range: Today, Yesterday, Last 7 days, Last 30 days, This month, Last month, All time, or Custom range. This filter selects the range of when the translations were added.
Additionally, using the report’s Settings, you can configure Match Score Categories. These settings determine how the graph groups translations that were edited. For example, if you set a category for 99-90%, source strings where the approved translation matches the initial translation within that range will be grouped together. Anything below your lowest defined match category will be treated as No Match (New Translation).
To generate the Translator Accuracy report, follow these steps:
  2. (Optional) Select one or more users if you want to generate the report for specific translators only. Otherwise, choose All to include everyone.
  3. Select the preferred language or choose All if you want to include every target language.
  4. Select the Date Range.
  5. (Optional) Select Files to specify the source content. You can choose All files or Selected files.
  6. (Optional) Select Labels to filter strings based on their labels. You can choose Strings with selected labels or Strings without selected labels.
  7. (Optional) Clear Save to archive if you don’t want to save the report to the Archive.
  8. Click Settings to configure your Match Score Categories.
  9. Click Generate.
When the report is generated, you will see the information grouped by language, and each translator is listed with their individual statistics.
In each section, the data is displayed as a Pie Chart. The chart visualizes the proportion of source content based on how closely the translator’s initial work matched the final approved version:
  • 100% Match – The number of source units where the approved translation matches the translator’s initial translation exactly (approved without edits).
  • Match Score Ranges (e.g., 99-90% Match) – The number of source units where the approved translation is an edited version of the translator’s work but remains similar within the configured percentage range.
  • No Match – The number of source units where the approved translation differs significantly from the translator’s initial work (below the lowest configured match category). In these cases, the translation was changed so significantly during proofreading that it is treated as a complete rewrite (a new translation).
To download the Translator Accuracy report, click Export and select the preferred export format (CSV, XLSX, or JSON).
Translator Accuracy Generated
Use this report to calculate the cost of work based on the time contributors spend on tasks. This report is particularly useful when paying translators and proofreaders by the hour rather than by the volume of content (e.g., words).
The report uses the time logged by contributors directly in a task’s comments.
  • Member: All or specific members.
  • Task Type: All, Translate by own translators, Proofread by own proofreaders, Translate by vendor, or Proofread by vendor.
  • Group by: Member, Language, or Task.
  2. Set your rates.
  4. (Optional) Clear Save to archive if you don’t want to save the report to the Archive.
  5. Click Generate.
You can set the hourly prices for work done by contributors in the project. Unlike the Translation Cost report, the unit for the Time Spent report is fixed to hour.
In the Base Rate section, you can set the hourly rate that will be applied to all work types (translation and proofreading) done in the project. This rate serves as the default for all languages and members.
In addition to the base rate that is applied to all languages and users by default, you can add custom rates for specific languages and users. To add custom rates, click Add custom rates.
When the Time Spent report is generated, it displays the following details:
  • Total - The total calculated cost and total time spent for the selected time period.
  • User/Language/Task Totals - The report shows totals for each member, language, or task, depending on the selected Group by filter.
Below the summary, the report shows a detailed breakdown in a table format:
  • Language – The target language for the work performed.
  • Time Spent – The total time logged by the contributor for the work in that language.
  • Rate per hour – The hourly rate applied (based on your configured Base Rate and Custom Rates).
  • Price – The total cost calculated for the work in that language.
In addition to the Translation Cost report, which is based on the Contribution Raw Data and grouped by languages, you can retrieve this detailed contribution raw data using the Generate Report (Contribution Raw Data schema) or via the Raw Report Data app available on the Crowdin Store. This allows you to generate your own custom report according to your specific requirements.
The Contribution Raw Data report provides various columns depending on the selected mode (translations, approvals, or votes). Each column offers specific insights, for example source string text hash, which is useful for identifying changes in source strings despite having the same stringId. It’s important to note that multiple records can exist for the same stringId if the source hash or plural form varies.
For repeated translations by the same user on the same source string, into the same target language, the same plural form, and if the source text has not changed, only the translationId, targetUnits, and updatedAt columns will update in the report statistics. Deleted translations are also included in the count. Understanding these columns can help you better interpret the raw data and optimize your localization process.
View the available report columns and their mode applicability (i.e., translations, approvals, and votes) in the following table:
NameAvailable in Report ModeDescription
userIdTranslations, Approvals, Votes
Type: integer
Numeric identifier of a user who added a translation.
languageIdTranslations, Approvals, Votes
Type: string
Target language identifier (Crowdin language code (e.g., uk)).
stringIdTranslations, Approvals, Votes
Type: integer
Numeric string identifier in Crowdin project.
translationIdTranslations, Approvals, Votes
Type: integer
Numeric identifier of the translation in Crowdin project.
fileIdTranslations, Approvals, Votes
Type: integer
Numeric file identifier in Crowdin project where the source string is stored.
filePathTranslations, Approvals, Votes
Type: string
Path to the file that contains the source string (e.g., /main/docs/index.md).
pluralFormTranslations, Approvals, Votes
Type: string
Translation plural form (each plural form is displayed as a separate record in the report).
sourceStringTextHashTranslations, Approvals, Votes
Type: string
Hash of the source string.
mtEngineTranslations, Approvals, Votes
Type: string
MT engine name from which a translation was provided.
mtIdTranslations, Approvals, Votes
Type: integer
Numeric MT engine identifier.
tmNameTranslations, Approvals, Votes
Type: string
Translation memory name from which a translation was provided.
tmIdTranslations, Approvals, Votes
Type: integer
Numeric translation memory identifier.
preTranslatedTranslations, Approvals, Votes
Type: string
Specifies if a translation was applied via auto-translation.
tmMatchTranslations
Type: integer
The highest match value of the translation with other TM suggestions, if any.
mtMatchTranslations
Type: integer
The highest match value of the translation with other MT suggestions, if any.
suggestionMatchTranslations
Type: integer
The highest match value of the translation with suggestions from other translators, if any.
sourceUnitsTranslations, Approvals, Votes
Type: integer
Specifies the number of words in the source text (available only if strings unit type is not selected).
targetUnitsTranslations, Approvals, Votes
Type: integer
Specifies the number of words in the translation (available only if strings unit type is not selected).
createdAtTranslations, Approvals, Votes
Type: datetime
Specifies the date when the string was initially translated.
updatedAtTranslations, Approvals, Votes
Type: datetime
Specifies the date when the last translation was added.
markVotes
Type: string
A vote mark that indicates how the translation rating has changed (e.g., if a translation has been voted up or down, or if the vote has been canceled).
The Top Members report allows you to see who contributed the most to your project’s translation over time. This list includes all users who have ever contributed, even if they are no longer current project members.
Default parameters:
  • Text unit: words
  • Time period: Last 30 days
  • Languages: all languages
  • Contributors: all
Re-sort the members by clicking on the needed parameter. For example, if you want to analyze members by their proofreading activity, click on the Approved parameter to redo sorting.
  1. In the upper-right corner, select the preferred report unit (words, strings, characters with or without spaces).
  2. In the Date Range field, select the time period for which you want to see the activity of contributors.
  4. Click Generate.
To find a specific member, use the search field. To open the member’s profile page, double-click on the name.
  • Target Words / Characters / Characters with Spaces – the number of translated content units in a target language.
  • Winning – the number of source content units in the contributor’s translations that were approved, counted once for each approver.
  • Joined – the date a member joined a project.
To download the Top Members report, click Export and select the preferred export format (CSV, XLSX, or JSON).
In the Archive section, you can access the records of previously generated Cost Estimate, Translation Cost, Auto-Translation Accuracy, Translator Accuracy, and Time Spent reports and review historical data.
Each project has its own independent archive section with previously generated reports available only to project members with manager permissions (or higher).
Reports generated by project members without manager permissions are also saved to the archive, but only the member who generated a report can access it.
  1. Open your project and go to Reports > Archive.
  2. Double-click the needed report in the list. Alternatively, click on it and select View.
The record shows the same results as the generated report. To download it, click Export and select the file format. For Cost Estimate and Translation Cost records, click Rate Schema to see the rates and settings the report was generated with.
  2. Click on the needed report in the list.
  3. Click Delete.
Bu sayfa faydalı oldu mu?
