Puoi configurare le impostazioni del progetto secondo le tue esigenze nella scheda Impostazioni.
For convenient navigation, all project settings are grouped as follows:
- Generale
- Access
- Traduzione
- Languages
- Controlli QA
- Memoria di traduzione
- Glossario
- Contenuto
- Import
- Export
- Parsers configuration
Generale
Nome
In the Name section, you can change the project name and add a public description.
Branding
The custom domain lets you publish your Crowdin project on your own domain name.
To set up a custom domain, follow these steps:
- Create a necessary domain in the domain name registrar.
- Create a CNAME record for this domain name that will be pointed to
cname.crowdin.com
. - Open your Crowdin project and go to Settings > General > Branding.
- Enter the created domain name into the Custom Domain field and click Update.
The project logo allows you to customize the appearance of your project’s main page.
Distintivi
With badges, you can share the localization progress of your Crowdin project by embedding them into your website or README.
To embed badges, follow these steps:
- Open your Crowdin project and go to Settings > General > Badges.
- Enable Display badges.
- Copy the badge code using Markdown, HTML, or Image URL.
- Paste the badge code on your website or README.
Elimina progetto
This option is accessible exclusively to the project owner. You can delete your Crowdin project with all the translations and related localization resources if necessary.
Note! This action can't be undone.
Privacy & Collaboration
Visibilità del progetto
Set the preferred visibility for your project with the following options:
- Public project – public projects can be found via search engines and Crowdin search. Crowdin users can join public projects without approval if the Moderated project joining option is disabled.
- Private project – private projects can’t be found via search engines and Crowdin search. Only the invited users can join the project.
Privacy
Configure your project privacy settings with the following options:
- Require two-factor authentication for all the project members – request project participants to enable two-factor authentication in their Account Settings > Password & Connections tab to access the private project.
- Moderated project joining – require users to send requests to join the translation team of the preferred language. Dopo la revisione, un gestore del progetto o revisore può approvare o rifiutare la richiesta. After joining the project, multilingual translators can submit new requests to join translation teams in other target languages.
- Allow offline translation – allow translators to download source files to their machines for offline translation and upload translations back into the project. The project owner and managers can always download sources and upload translations, not depending on the option status.
- Allow proofreaders to access hidden strings – allow proofreaders to work with hidden strings. The project owner and managers can always work with hidden strings, not depending on the option status.
- Allow project members to manage glossary terms – allow translators and proofreaders to add new glossary terms to the project. The project owner and managers can always add and edit glossary terms, not depending on the option status.
- Show machine translation suggestions – enable MT suggestions from machine translation engines such as Microsoft Translator, Google Translate, and others to be displayed in the Editor. Il proprietario del progetto dovrebbe configurare i motori di traduzione automatica, prima di usarli.
Notifiche
- Notify translators about new strings – translators will receive an email notification about newly added content for translation each time after the update. The Receive emails option should be activated in the translator’s profile.
- Notify project managers about new strings – project managers will receive an email notification about newly added content for translation each time after the update.
- Notify project managers about language translation/validation completion – project managers will receive the notification when some target language (all source files) is fully translated or fully validated.
Languages
In the Languages section, you can manage your project source and target languages and configure language mapping to use custom language codes.
Lingua di Origine
If you want to change the source language for your project, select a new language from the drop-down list and click Update.
Ecco alcuni punti di cui dovresti esser consapevole modificando la lingua d’origine del progetto:
- Sei pregato di notare che potrebbe esserci una mancata corrispondenza del modulo plurale per le stringhe importate, a seconda della nuova lingua di partenza. Ad esempio, alcune forme plurali potrebbero non apparire nell’Editor, o alcune traduzioni della forma plurale potrebbero esser usate in altre all’esportazione della traduzione. Consigliamo di aggiornare i file di origine se la nuova lingua d’origine ha forme plurali differenti di quella iniziale.
- Se avevi aperto la scheda del browser con l’Editor durante l’aggiornamento della lingua d’origine, potresti doverla ricaricare affinché le modifiche siano effettive e per continuare a tradurre dalla nuova lingua d’origine.
Lingue di Destinazione
The Target Languages section allows you to add or remove target languages in your project, copy the target languages list from one project to another, and add custom languages.
Read more about Target Language Management.
Aggiungere Codici di Lingua Personalizzati
To add language mapping, follow these steps:
- Open your project and go to Settings > Languages.
- Scroll down to the Add custom language codes section.
- Click Language Mapping.
- Scegli la lingua e il segnaposto necessari.
- Aggiungi il codice personalizzato.
- Puoi mappare quante più lingue necessarie. Click Add Mapping to add another custom code.
- Click Save.
Controlli QA
In the QA Checks section, you can manage the types of QA issues to be highlighted in the Editor during the translation process.
Read more about Quality Assurance Checks.
La TM del progetto è creata automaticamente per ogni progetto. Therefore, every approved or the latest added translation is automatically saved to the project TM.
- Enable Auto-Substitution – the feature substitutes the non-translatable elements (such as tags, HTML entities, placeholders, numbers, and more) in TM translation suggestions with the ones used in the source text. The feature improves the TM suggestions applied during pre-translation and those shown as translation suggestions in the Editor. Improved suggestions are included in the Translation Costs report, and improvable ones are included in the Costs Estimation report.
Use the global Translation Memory – translators will have access to the Global Translation Memory, where all translations from the projects with this feature enabled are stored.
Note: Once this option is enabled, translations made in this project will also be added to the Global Translation Memory, which anyone can access at Crowdin.
In the Assigned Translation Memories section, you can assign and manage the translation memories for your project.
Read more about Translation Memory.
Glossario
In the Glossary section, you can enable the translation of the glossary.
In the Assigned Glossaries section, you can assign and manage the glossaries for your project.
Read more about Glossary.
Import
Stringhe Sorgente
Unify Placeholders – if your project contains iOS strings, iOS XLIFF, and Android XML files, you can enable the Unify placeholders option, and the system will transform placeholders into a unified look. For example, Crowdin will make the Android string Hello, %s!
, and the iOS string Hello, %@!
look in the Editor this way: Hello, [%s]!
. This option is beneficial when you work with TM since TM suggestions from iOS strings, iOS XLIFF, and Android XML will be completely interchangeable. Crowdin will transform the translation placeholders back to the original format on export. This option only applies to iOS strings, iOS XLIFF, and Android XML formats.
Duplicate Strings – if your project contains duplicated strings, you can choose how the system should treat them using the following options:
- Mostra: i traduttori tradurranno separatamente ogni istanza (stringa). Le stringhe duplicate non saranno nascoste.
- Mostra, ma traduci automaticamente: Le stringhe duplicate saranno tradotte automaticamente ma rimarranno visibili ai traduttori. Una volta tradotta la stringa, la sua traduzione sarà automaticamente condivisa tra i duplicati. I traduttori possono revisionare e tradurre nuovamente tali stringhe, se necessario.
- Mostra in un ramo della versione (rilevamento regolare): i duplicati saranno nascosti solo tra i rami della versione.
- Mostra in un ramo di versione (rilevamento rigoroso) – i duplicati saranno nascosti solo tra rami di versione.
- Nascondi (rilevamento regolare) – tutti i duplicati condivideranno la stessa traduzione.
- Nascondi (rilevamento rigoroso) – tutti i duplicati condivideranno la stessa traduzione.
Regular duplicate detection – when comparing strings, Crowdin considers only source texts.
Strict duplicate detection – when comparing strings, Crowdin considers both string identifiers (keys) and source texts.
If your source files contain strings with apparent identifiers (keys), it’s better to use a strict version of the Duplicate Strings options. In other cases, feel free to use a regular one.
Conteggio delle parole
You can set the preferred way Crowdin should count words in your project. Nello specifico, si applica a seconda del fatto che i tag HTML debbano esser contati come parole regolari o no. By default, Crowdin considers HTML tags as regular words for most of the supported formats, excluding the following ones: HTML, Front Matter HTML, HAML, MD, Front Matter MD, XML, WEBXML, IDML, XLIFF, XLIFF 2.0, ADOC, DOCX, MIF, DITA.
- Auto (default) – HTML tags will be counted as regular words or skipped depending on the source file format.
- Count tags – all HTML tags will be counted as regular words.
- Skip tags – all HTML tags won’t be counted.
When you change the word count option, only newly uploaded words will be counted according to the new settings. Quindi, si consiglia di impostare le impostazioni di conteggio delle parole preferite prima di caricare i file d’origine nel progetto.
Export
By default, when exporting translations, Crowdin fills untranslated strings with source text to avoid exporting empty files.
You can configure export options using the following settings:
- Save context information in the files – the context and max.length added in Crowdin will be visible in the downloaded files. This option only applies to CSV, Android XML, iOS strings, and RESX formats.
Note: This option only partially applies to iOS strings and RESX formats (i.e., only the context added in Crowdin will be visible in the downloaded files).
Skip untranslated strings – only translated strings will be included in the exported translation files.
Quest’opzione funziona in tre modi diversi, a seconda del formato del file. This option is not applied to text-formatted documents since missing texts can make downloaded files unreadable. Gli altri sono esportati con valori vuoti. And for the third file category, untranslated strings are entirely removed from the exported translation files.
Opzione non applicata | Stringhe non tradotte, esportate con valori vuoti | Stringhe non tradotte rimosse |
DOCX, IDML, DITA, ADOC, MD, MediaWiki, TXT, HAML, HTML, assets, FM MD, FM HTML, Contentful JSON, SVG | JSON (con struttura nidificata), PHP, XLSX, CSV, FJS, RC, XAML, XML, Web XML, TypeScript, JS, TOML, QT TS, i18next JSON, gettext PO, FLSNP, Coffee | Android XML, macOS/iOS Strings, Stringsdict, Chrome JSON, JSON (senza la struttura nidificata), YAML, XLIFF, XLIFF 2.0, ARB, DTD, RRC, GO JSON, Flex, Joomla INI, Maxthon, Java Properties, Play Properties, Java Properties XML, RES JSON, RESW, RESX, SBV, STR, STF, VTT, WXL, VDF, FBT JSON |
- Skip untranslated files – only translated files will be included in the exported translation archive.
Note: if this option is enabled, it overrides the effect of the Skip untranslated strings option.
- Export only approved translations – only texts that are both translated and approved will be included in the exported translation files.
- Automatically fill in regional dialects – useful when the project is translated into the language dialects (e.g., Spanish, Argentina). On export, translations from Spanish will be automatically copied to untranslated strings in Spanish, Argentina.
Parsers Configuration
By default, Crowdin uses a predefined set of import and export parameters for each supported file format.
With Parsers configuration, you can change some of these settings according to your needs.
Read more about Parsers configuration.
Vedi Anche
