Gestisci ruoli dei membri del progetto
With the help of roles, you can provide project members with the access they need to accomplish the job they’re responsible for. Both the owner and managers can invite project members and change their roles.
Ruoli del Progetto
Below you can see the roles and permissions users can have in Crowdin Enterprise
  • Owner – a person who created a project and has complete control over it. The owner can invite and manage project members, create projects, upload source and translation files to the project, set up integrations, etc.
    Nota: La proprietà del progetto non è modificabile.
  • Manager – has similar rights as a project owner except the ability to manage some of the owner’s Resources (e.g., configuring MT engines, custom workflows, etc.) and delete projects.
  • Language Coordinator – can translate and approve strings - same as proofreaders. Additionally, can manage project members and join requests, generate project reports, create tasks, and pre-translate the project content. Language coordinator can do these actions only within languages they have access to. They don’t have access to other project settings (e.g., project files, integrations, etc.).
  • Proofreader – can translate and approve strings. Doesn’t have access to project settings.
  • Translator – can translate strings and vote for translations added by other members.
  • Blocked – doesn’t have access to the project.
Modificare il Ruolo del Membro
To change the role of a project member, follow these steps:
  1. Apri il tuo progetto e vai alla scheda Membri.
  2. Click Details toward a needed member in the list.
  3. In the appeared dialog, switch to the Permissions tab.
  4. Select a new role.
  5. Click Save.
Permessi della Lingua
By default, when you invite translators to your project, they will have access to all target languages.
To configure more specific access to target languages for your translators, follow these steps:
  4. Select the needed languages a member should have access to. You can simultaneously set both the Translator and Proofreader roles to the same member with specific language permissions (e.g., Translator with access to Ukrainian and Proofreader with access to French).
  5. Click Save.
Configuring Language Permissions
Q&A
D: Sono il proprietario di un progetto. Devo invitare un manager o un revisore?
A: The main difference between a manager and a proofreader is the following: in addition to approving translations added by translators, managers can also invite and remove project members, upload source and translation files to the project, set up integrations, etc.
Se desideri avere un membro del progetto che dovrebbe avere accesso alle funzionalità suddette, dovrai invitare un manager del progetto. Altrimenti, se pianifichi di gestire da solo il progetto, basterà invitare un revisore.
Questo articolo è stato utile?
