Scopes let you set the exact access type you need. Scopes limit access for the personal access tokens, OAuth tokens, and Crowdin apps. De giver ikke yderligere tilladelser ud over dem, brugeren allerede har i en organisation.
De for OAuth-appen angivne udstrækninger i Enterprise vil fremgå på brugernes godkendelsesformularer.
Navn | Key | Beskriveslse |
All scopes | all | Grants access to perform any of the following actions. |
Notifikationer | notification | Grants access to the list of enabled notifications, the ability to subscribe to a channel, as well as unsubscribe from it. |
Translation memories | tm | Grants access to manage project Translation Memory files. |
Machine translation engines | mt | Grants access to get the list of Machine Translation engines connected, as well as to create, delete MT engines, and update their settings. |
Udbyder | leverandør | Grants access to get the list of Vendors. |
Glossaries | ordliste | Grants access to manage the files with the project terminology. |
Teams | team | Giver adgang til brugerteams. |
Grupper | gruppe | Giver adgang til at håndtere projektgrupper, en bruger har adgang til. |
Projekter | project | Grants access to manage project a user has access to. |
Opgaver | project.task | Grants access to task lists, permission to create, delete, and update project tasks. |
Rapporter | project.report | Grants access to reports list, permission to generate, and export project reports. |
Translation status | project.status | Grants access to translation status for the projects: current translation issues, translation progress on different levels: file, language, branch, directory. |
Source files & strings | project.source | Grants access to add, get, delete, and update project branches, directories, source files, and source strings, as well ass access to the file revisions. |
Webhooks | project.webhook | Grants access to read or write hook configurations on repositories a user manages. |
Translations | project.translation | Grants access to add new and manage existing translations. |
Skærmfotos | project.screenshot | Grants access to get screenshots list, add, get, replace, and delete screenshots, ability to access and modify screenshot tags. |
