Custom Notifications notify and help you collect information about the new events that happen in Crowdin. Once you configure custom notifications for your account, Crowdin will start sending POST requests with data to the custom notification URL via HTTP.
You can configure custom notifications to build integrations with the services or with your backend. For example:
To configure custom notifications in Crowdin, follow these steps:
You will need to provide the following information to set up custom notifications:
Optionally, you can add special headers to your custom notifications. They can be used for additional security, as an authorization method, and more. For example, if you add headers, your custom notification endpoint can verify them and ensure that information is coming from Crowdin.
When configuring custom notifications, click Test notification to see how your application will react to that call. Once finished with the configuration, click Save.
Depending on your approach to custom notifications management, you might need to add dedicated Crowdin IP addresses to your firewall to allow Crowdin to open the pre-configured custom notification URLs.
Read more about IP Addresses.
You can modify the custom notification payload to add and organize the elements the way your system requires. To get informative and user-friendly notifications, make sure to include the {{notification-message}}
placeholder in your payload.
Once you configured custom notifications, you can select the event types you’d like to receive the notifications about in the Custom column.
You will be able to edit or delete custom notifications in the Custom notifications section of the Notifications tab.
Need help working with Custom Notifications or have any questions? Contact Support Team.
