Target file bundles or simply Bundles is the feature that allows you to export sets of strings or files in the formats you select, regardless of the original file format. By default, you can choose from the following three formats: XLIFF, Android XML, and iOS Strings. You can add more target file formats by installing respective applications from the Crowdin Store.
You can work with bundles in several ways:
- Manage bundles manually via the project’s Download tab.
- Connect a VCS integration in Target file bundles mode. For string-based projects, this is the only mode that is selected by default.
- Manage bundles using OTA Content Delivery.
- Manage bundles using Crowdin CLI and API.
When you work with bundles, the primary location for managing (creating, editing, and deleting) them is the project’s Download tab (for String-based projects). Once you’ve created a bundle, you can use it with all the aforementioned tools.
Use Cases
The most common use cases are the following:
- You can upload a single source file (e.g., Android XML) to your project, translate it, and then, using bundles, export translations for multiple platforms (e.g., Android XML for the Android app, iOS strings for the iOS app, JSON for the web app, etc.).
- You can have a single spreadsheet (e.g., XLSX or CSV) where you store source strings for all platforms your app is developed for, and each string is labeled with a respective label. Upload this file to your project, translate it, and then create separate bundles for multiple platforms using a combination of source file paths and string labels.
- You can localize your mobile app without source files by combining Crowdin design tool plugins (Figma, Sketch, Adobe XD) to send strings straight to the Crowdin project and export translations in the preferred formats using bundles.
- You can export specific sets of strings for offline translation in XLIFF format and then upload finished translations back to Crowdin.
Managing Bundles in Download tab
To work with bundles manually, you can configure and download them in your project’s Download tab.
Configuring Bundles
To configure a bundle, follow these steps:
- Open your project and go to the Download tab.
- Click Target File Bundles to expand the respective section.
- Click Add bundle.
- In the appeared dialog, name your bundle.
- Specify the source branches and resulting file paths. If needed, you can add multiple source branch path patterns using
. In the right panel, you can preview the source branches and structure of the translation files based on the specified paths. - (Optional) To ignore some branches, click Add ignored pattern, specify their respective pattern, and Crowdin will skip these specific branches during the bundle generation. If needed, you can add multiple ignore patterns using
. - (Optional) You can specify labels in the Filter by labels and Exclude by labels fields to filter strings, including or excluding them in the generated bundle.
- Select the file format you’d like your strings to be exported in. To add other formats, install the respective applications from our Store.
Note: You can select only one format at once within a single bundle.
- (Optional) If a bundle file format has a
icon, it indicates that it has additional options (e.g., Copy source to empty target and Export Translator’s Comments for XLIFF (system), Convert placeholders to target file format for Android XML (system), etc.) you may use when setting up your bundle. Click the
icon on a selected bundle file format and configure it according to your preferences.
![Configure Bundle File Format](/assets/docs/bundles_configure_format.png)
- Click Save.
![Create Bundle](/assets/docs/bundles_create_bundle_sb.png)
To download configured bundles, follow these steps:
- Click Download toward the needed bundle.
![Download Bundle](/assets/docs/translations_bundles_sb.png)
The system will build and download a ZIP archive with folders for each of the project’s target languages containing the translation files of the selected format.
Editing Bundles
To edit configured bundles, follow these steps:
- Click
toward the needed bundle and select Edit. Alternatively, just double-click on the needed bundle. - Make the necessary edits and click Save.
![Edit bundle](/assets/docs/bundles_edit_bundle_sb.png)
Deleting Bundles
To delete bundles, follow these steps:
- Click
toward the needed bundle and select Delete. - Confirm the deletion by clicking Delete in the appeared dialog.
![Delete bundle](/assets/docs/bundles_delete_bundle_sb.png)
Bundles in VCS Integrations
In string-based projects, VCS integrations exclusively operate in the Target file bundles mode.
To configure a VCS integration for Target file bundles mode, follow these steps:
- Once you click Set Up Integration and authorize the connection with Crowdin on the VCS side, select the repository and branches to which you want to send translations.
- Click
to start the configuration of the selected branch. - In the Branch Configuration dialog, specify the preferred name for your configuration file or leave it as is and click Continue.
- Select the needed bundles from the list or click Create new to create one from scratch.
- Once you’ve selected all the needed bundles in the Branch Configuration dialog, click Save.
- To complete the VCS integration configuration, click Save in the dialog where you selected your repo and branches.
![VCS Target File Bundles Mode](/assets/docs/bundles_vcs.png)
Read more about configuring VCS integrations online.
Bundles in OTA Content Delivery
To add a distribution that exports translations using bundles, follow these steps:
- Click Over-The-Air Content Delivery to expand the respective section.
- Add new distribution using the Add distribution button.
- In the appeared dialog, name your distribution.
- Once you’ve selected all the needed bundles in the Add distribution dialog, click Next.
![OTA Content Delivery Bundles](/assets/docs/bundles_content_delivery_sb.png)
- Copy the distribution hash so you can use it for integration.
Read more about OTA Content Delivery.
Bundles in CLI/API
You can also export translations using bundles when working with Crowdin CLI and API.
Read more about Bundles in CLI.
Read more about Bundles in API.
