I motori di traduzione automatica integrati con Crowdin forniscono suggerimenti di traduzione dai servizi di traduzione automatica come Google Traduttore ed AutoML Translation, Microsoft Translate, Yandex.Translate ed altri. I suggerimenti fatti da motori a macchina sono mostrati nell’Editor, sotto il campo suggerimenti dei traduttori. Inoltre, puoi fare pre-traduzione usando motori di traduzione automatica.
By default, machine translations are enabled for each project, but it is required to configure the translation engines before the project members can use them. In case you want to disable this option for specific projects, clear Show machine translation suggestions in the project settings.
To configure the machine translation engines, follow these steps:
As soon as you specify your MT engine credentials, the system will automatically assign a unique MT engine ID. Later on, you can use these IDs in API requests for pre-translation via machine engines.
Vai al Windows Azure per accedere alla tua chiave di iscrizione all’API Microsoft Translator. Translator Text API offers a free tier with 2,000,000 translated characters.
Come iscriversi per la API Microsoft Translator Text.
Usa le tue API Console Yandex per ottenere la tua chiave API Yandex.Translate. Translation projects that do not exceed 10,000,000 characters per month (and no more than 1,000,000 in 24 hours). You can use Yandex.Translate API for free.
DeepL API is accessible only with the DeepL API subscription plan (For developers tab). Navigate to the DeepL Pro Account page to get a unique Authentication Key. Please note that the DeepL API plan is the only plan that provides this feature.
In case you’re subscribed to a different subscription plan, you can switch to the DeepL API plan in your personal account settings. DeepL also provides a simulator that allows you to check your Authentication Key in action.
Watson (IBM) Translator offers 1,000,000 characters per month free of charge and paid plans to choose from after exceeding the limit. Vai alla Console Watson (IBM) Services per ottenere la tua chiave API Watson Translator.
The free version of Amazon Translate is available for 12 months. Afterward, you will need to pay for the number of characters translated.
To obtain the API key and Secret key necessary for integration, follow these steps:
When logged in, click on your username in the top right corner and select My Security Credentials. In the section with access keys, click Create New Access Key.
If you don’t have access to this section, ask the Amazon AWS profile administrator to create an IAM user for you.
To use Google Translate, you shall have a Google Cloud account with an active billing profile. Cloud Translation ha un prezzo mensile basato sull’uso. Scopri di più
To obtain the API key necessary for integration, follow these steps:
Translate your projects using custom models that you create using Google Cloud’s AutoML Translation. This way, you can get more accurate translations for customer-specific terminology.
To use AutoML Translation, you shall have a Google Cloud account with an active billing profile. Google AutoML Translation è prezzato mensilmente in base a quanti caratteri invii per la traduzione. Scopri di più.
To create a service account key and obtain the necessary credentials for integration, please follow these steps:
Per configurare l’autenticazione e creare la tua chiave privata, segui questi passaggi:
