The GitHub integration allows you to synchronize translations from your Crowdin project to GitHub repo.
In string-based projects, GitHub integration exclusively operates in the Target file bundles mode.
Target file bundles mode – generate and push translation files to your GitHub repository from the Crowdin project in the selected format. In this mode, integration pushes translation files and doesn’t sync sources from your repo. In cases when you perform a source text review in your Crowdin project and want to get updated source texts to your repo, you can add a source language as a target language, which will be pushed to your repo along with translations.
All completed translations are collected into bundles and automatically pushed as a merge request to the l10n
branch in the GitHub repository.
In case the repository you need is private, and you have limited or no access to it, please ask the repository owner to provide you with an Access Token. Afterward, click Use personal access token and insert the token into the Token field and click Set Up Integration.
In the appeared dialog, select your repository and branches that should be translated.
GitHub integration in the Target File Bundles Mode will send the completed translations from your Crowdin project without pulling sources from your repo. So when selecting a repository and branches that should be translated, you specify where the integration should put the generated bundles with translations.
Read more about configuring target file bundles for VCS integration.
When you work with private integrations (e.g., integrations with self-hosted VCS), you need to add dedicated Crowdin IP addresses to the allowlist to ensure that it operates properly while staying secure.
Read more about IP Addresses.
When translations are finished and your languages are ready to go live, Crowdin sends the pull request with translations to your version control system. For every branch that is under localization, Crowdin creates an additional service branch with translations. We don’t commit directly to the master branch so that you can verify translations first.
By default, l10n_ is added to the created service branch name. If necessary, you can easily change it.
There are cases when it’s necessary to disable translations from being pushed to the repo temporarily. In this situation, click Edit, clear Sync Schedule in the integration settings, and click Save. When ready to sync translations with the repo, select the Sync Schedule, and click Save.
The synchronization is processed every hour automatically. If necessary, you can change the update interval in the integration settings. To configure the synchronization schedule – click Edit, scroll down to the Sync Schedule, set the preferred interval, and click Save.
When you set up the integration, you select existing repository branches to be added to the Crowdin project. To add future branches from GitHub to Crowdin automatically, create a pattern for the branch names in the integration settings.
For example, you add a pattern *feature in the GitHub integration settings. In this case, the future branches that contain this word at the end of the title will be added to the project.
To add a pattern for branch names, follow these steps:
crowdin.yml
is the default file name that is used for automatically synchronized branches. To change the default settings, click Edit, specify the preferred name in the Default configuration file name field in the integration settings, and click Save.
If you don’t specify your custom configuration file name for automatically synchronized branches, and the integration doesn’t find a configuration file with the default name crowdin.yml
in the root of the branch, these branches will be marked in the integration settings with a red icon with an exclamation mark saying “Not Ready. Check the configuration”.
To make integration work in the Target file bundles mode, you need to select the required bundles that you want to push to your repository. If you see a red icon with an exclamation mark next to the service branch name, it means that you haven’t selected any content for synchronization.
There are two ways you can specify content for synchronization:
This procedure is the same for all integrations with version control systems (VCS). Read more about configuring target file bundles for VCS integration.
The configuration file crowdin.yml
should be placed in the GitHub repository along with each separate branch you want to push translations to, so that Crowdin knows exactly which translation bundles to send to your repository.
It should have the same structure as required for CLI, but your project’s credentials should not be stored in the file’s header for security reasons.
Read more about creating a configuration file.
If you’re working with a multi-platform product that has versions for different operating systems, you may want to connect multiple repositories that store content for each operating system. In this case, localization resources (e.g., TMs, Glossaries) and translations could be used more efficiently, reducing the time needed for project localization.
To add another repository, follow these steps:
Once the integration is set up, all related information is stored in the Integrations tab > GitHub section.
After the integration is connected, the settings can be updated only by the project member who configured it. All project managers except the person who configured the integration will see the Edit button disabled with the following message when hovering over it: Integration was configured by {Full Name} ({username})
By default, synchronization is processed every hour automatically. If you need to launch the synchronization immediately – click Sync Now.
Alternatively, if you need to sync only one branch separately, click on the needed branch and select Sync branch.
Q: What should I do if my repository becomes a part of the GitHub organization?
A: To continue using GitHub integration in Crowdin, follow these steps:
Q: I have an application build configured to be triggered by every commit. Since Crowdin commits each translation file in a separate commit, how can I avoid unnecessary application builds triggered by commits from Crowdin?
A: Since VCS integrations in Crowdin use API to commit files but not Git, each file is committed separately.
Here are a few recommendations that might help solve similar situations:
export_languages
option to skip commits from languages you’re not interested in yet. Read more about the Export languages parameter for VCS integrations.
