Maintain an agile localization process and prevent translation delays for added texts or new product features. Integrate your project branches with Crowdin Enterprise and allow translators to access all new texts immediately.
When several people work on product development, branches help manage different content versions. If you have a continuous project, you can add project branches to Crowdin Enterprise and allow translators to translate the texts in parallel with development to prevent deployment delays.
Branches in Crowdin Enterprise look like regular folders marked with a specific icon and have special behavior for duplicate strings.
Example of branch structure in Crowdin Enterprise:
There are a few ways to add branches to Crowdin Enterprise:
To create a branch via API, use the Add Branch method.
If you use CLI, you can add and delete version branches with dedicated commands. Alternatively, you can create version branches during the file upload.
Read more about Branch Management with CLI.
You can set a specific priority for each branch by clicking an arrow icon next to the needed branch. Then translators will see branches sorted according to their priority on the language page and in the Editor.
Branches might have the following priorities:
To set a priority for your branches, follow these steps:
Because branches are different versions of the same product feature, their localization content is usually duplicated. Щоб допомогти перекладачам узгоджено перекладати версії та уникнути додаткових витрат на переклад, у нас є параметр Показати в межах гілки версії, який дозволяє приховувати повторювані рядки лише між версіями. If your source files contain strings with apparent identifiers (keys), it’s better to use a strict version of this option. In other cases, feel free to use a regular one.
When this option is chosen, only the master strings first uploaded to the system should be translated. All duplicated strings will automatically gain translations from the master strings.
To make sure versions work smoothly for your Crowdin Enterprise project, we recommend the following workflow:
На екрані нижче показано, як працює робочий процес на практиці. All texts from Master, Branch 1, and Branch 2 are transferred to the translation server immediately after they appear, even though the branches are not merged to the Master branch yet.
Translations from all version branches are placed in one ZIP archive when downloaded through the web interface. Use the CLI or API to download the translations for each branch individually.
To download translations of the specific version branch with API, you can use the following API methods:
Download translations of the specific version branch:
$ crowdin download -b branch_name
Гілка Master буде містити нові тексти з гілок Feature як тільки вони поєднуються. While synchronizing with Crowdin Enterprise, texts in the Master branch are populated with translations from the appropriate branch.
After synchronizing the updated Master branch with Crowdin Enterprise, you can remove the Feature branch from Crowdin Enterprise. Усі переклади зберігатимуться в цій гілці Master.
You can verify translations on production using only the Feature branch before changes are merged with your Master branch. Such test deployment allows you to quickly revert to the original Master branch version if needed.
