Файли
You can upload localizable files via Web UI, using one of the integrations, API, or console client (CLI).
To upload source files to your project via Web UI, follow these steps:
![Файли проекту](/assets/docs_enterprise/project_files.png)
- Click File in the upper-right corner and select Upload. Also, you can drag and drop files from your machine.
- Create folders and branches if needed.
Read more about Uploading Files.
Рядки
To manage source strings, follow these steps:
- Open your project and go to Sources > Strings.
- Using the drop-down menu in the upper-left corner, select the source file you want to view strings from.
![Project Strings](/assets/docs_enterprise/project_strings.png)
- Select the strings you want to modify.
![Selected Strings](/assets/docs_enterprise/project_strings_selected.png)
- Use the buttons in the upper-right corner to change the visibility, tag, or delete selected strings.
Read more about String Management.
Скріншоти
Provide your translators with additional context to the uploaded source files by adding screenshots. Позначте вихідні рядки на скріншотах, щоб вони відображалися в редакторі, де перекладачі побачать їх у розділі контекст.
To upload screenshots, follow these steps:
- Відкрийте ваш проєкт та перейдіть до вкладки Скріншоти.
- Drag and drop screenshots from your machine or click Upload in the upper-right corner.
![Скріншоти](/assets/docs_enterprise/project_screenshots.png)
To tag screenshots, follow these steps:
- Double-click on a screenshot.
- Tag corresponding strings to a screenshot.
Alternatively, select a screenshot and click Auto tag.
Read more about Screenshots.
