IP Addresses and Domains
When you work with private integrations (e.g., integrations with self-hosted VCS) or use a firewall for your company network, you need to add dedicated Crowdin Enterprise IP addresses and domains to the allowlist to ensure that it operates properly while staying secure. A similar approach is applicable when using Crowdin Enterprise webhooks. To allow Crowdin Enterprise to open the pre-configured URLs, add the respective IP addresses and domains to your firewall.
Note: The below-mentioned IP addresses are changed periodically.
Інтеграції
Crowdin Enterprise uses the following IP address to interact with the integrations:
52.45.158.111/32
Вебхуки
Crowdin Enterprise uses the following IP address to send the webhooks from:
3.224.117.103/32 44.194.158.59/32
Downloading Lists of Current IP Addresses
For your convenience, you can get the integration and webhook IP addresses in JSON format:
Domains
Crowdin Enterprise uses the following domains to provide its services from:
accounts.crowdin.com enterprise.crowdin.com <organization_domain>.crowdin.com <organization_domain>.api.crowdin.com production-enterprise-assets.downloads.crowdin.com production-enterprise-importer.downloads.crowdin.com production-enterprise-packages.downloads.crowdin.com production-enterprise-screenshots.downloads.crowdin.com production-enterprise-static.downloads.crowdin.com production-enterprise-tmp.downloads.crowdin.com enterprise-statics.crowdin.net distributions.crowdin.net badges.crowdin.net ws-lb.crowdin.com cdn.crowdin.com d2srrzh48sp2nh.cloudfront.net
Ця стаття була корисною?
