Crowdin SDK allows delivering new translations from the Crowdin project to your application immediately. Using integration with Crowdin SDK there will be no need to update the application in Google Play Store every time there is a new localization version.
The integration provides:
Requirements to integrate Android application with a project in Crowdin:
Development Tool
App Programming Language
Configure the distribution to mirror the translated content of your project and integrate with Android app. Read more about Distributions.
For more details on how to set up Crowdin SDK for your application visit our GitHub repository.
Required for all features | |
your_distribution_hash | Unique hash, which you can get by going to Settings > Content Delivery. To see the distribution hash, click ![]() |
Required for advanced features | |
source_language | Source language of your Crowdin project (e.g., "en"). |
client_id client_secret | Crowdin authorization credentials. Open the project and go to Settings > Content Delivery. In the For Mobile Applications section, click Get Credentials. |
Optional | |
network_type | Network type to be used. You may select NetworkType.ALL, NetworkType.CELLULAR, or NetworkType.WIFI |
interval_in_milisec | Update intervals in milliseconds |
You can set file export patterns and check existing ones using File Settings. The following placeholders are supported for Android integration:
Name | Description |
%language% | Language name (e.g., Ukrainian) |
%two_letters_code% | Language code ISO 639-1 (e.g., uk) |
%three_letters_code% | Language code ISO 639-2/T (e.g., ukr) |
%locale% | Locale (e.g., uk-UA) |
%locale_with_underscore% | Locale (e.g., uk_UA) |
%android_code% | Android Locale identifier used to name "values-" directories |
Crowdin Android SDK CDN feature is built with security in mind, which means minimal access possible from the end-user is required. When you decide to use Crowdin Android SDK, please make sure you’ve made the following information accessible to your end-users.
Q: What might cause the occasional delay in getting the latest translations in the app?
A: CDN caches all the translations in release for up to 15 minutes. When new translations are released in Crowdin, CDN may still return them with a delay.
