Migrating to Crowdin Enterprise
You can migrate your Crowdin projects with all related data, TMs, and Glossaries to your Crowdin Enterprise organization and continue the localization process without losing the current progress.
Read more about Crowdin Enterprise.
Data you can migrate includes:
  • Projects with related data
    • Source files
    • Project members
    • Translations
    • String comments
    • Screenshots
    • Labels
    • Custom processors (if any)
  • Translation Memories
  • Glossaries
Migration Settings
Before the migration starts, you need to select your Crowdin Enterprise organization, projects, and resources.
To configure your migration settings, follow these steps:
  1. Open Account Settings and go to the Profile tab.
  2. In the Migration to Crowdin Enterprise section, click Migrate Account to start configuring your migration.
Organization Step
On the first step of the migration, select a Crowdin Enterprise organization you will migrate your Crowdin account’s data to. You can log into your existing Crowdin Enterprise organization or create a new organization from scratch.
Select Crowdin Enterprise Organization
Once you’ve selected your Crowdin Enterprise organization, the system will ask you to authorize the Migrate Crowdin account to Crowdin Enterprise application and grant access to projects and groups within your organization. It’s necessary because the migrator app will create your projects and resources in Crowdin Enterprise on your behalf.
Grant Access to Your Crowdin Enterprise Organization
Projects Step
On the Projects step, you will see the list of your projects in Crowdin and your Crowdin Enterprise Workspace. Select the projects you’d like to migrate. By default, selected projects will be migrated to the organization’s Workspace. If needed, you can create separate groups for different projects.
Select Projects for Migration
Resources Step
On the Resources step, you will see the list of your Translation Memories and Glossaries. By default, resources related to the projects you selected in the previous step will be automatically selected. Select the additional ones you’d like to migrate. Then, click Migrate to start the migration process.
Select Resources for Migration
Migration Step
After you start the migration, you will be able to track its overall and detailed progress. Depending on the number of projects and resources, it might take from a few minutes to a few hours to migrate all the data. You will see the Migration to Crowdin Enterprise is in progress notification at the top of every page during the migration process. If needed, you can leave the Account Settings page. The migration will continue running in the background.
Note: The changes made on Crowdin after the migration started might not be migrated.
Migration in Progress
When the migration is finished, you can go to your Crowdin Enterprise organization and continue translating your projects.
Migration Completed
Was this article helpful?
