Console Client (CLI) v2
Note: If you are using the old version of Crowdin CLI (0.5.5 or less) see Crowdin GitHub for full details.
Note: We offer a new version of our CLI. To learn more, read the article CLI.
Crowdin CLI is a command line tool that allows you to manage and synchronize your localization resources with your Crowdin project:
  • Automate the process of updating your source files in your Crowdin project
  • Download translations from Crowdin and automatically save them in the correct locations
  • Upload all your existing translations to Crowdin in minutes
  • Integrate Crowdin with GIT, SVN, Mercurial, and more.
This is a cross-platform and it runs in a terminal on Linux based and macOS operating systems or in Command Prompt on Windows. It’s also open-source and it’s source code available at GitHub.
What's New
  • New type of YAML configuration
  • Validation of a configuration file with the help of lint command
  • Generation of a configuration file with the help of generate command
  • Improved process of files upload
  • Possibility to work with a single file without a configuration
  • --dryrun option to preview the list of managed files
Requirements
Check that you have Java 7 or newer installed. Type java -version command in the terminal (Command Prompt on Windows) to check Java version. For example, java version “1.7.0_55” means that you have Java 7 Update 55 installed.
If you don’t have Java installed, download it from Oracle’s website.
Installation
Homebrew for macOS
To install the Crowdin CLI with homebrew (the package manager for MacOS):
$ brew install crowdin
Windows
Download and run installer for Windows
Debian
We sign all our packages with the Crowdin Signing Key.
Download and install the public signing key:
wget -qO - https://artifacts.crowdin.com/repo/GPG-KEY-crowdin | sudo apt-key add -
Using the following command, create the crowdin.list file in the /etc/apt/sources.list.d directory:
echo "deb https://artifacts.crowdin.com/repo/deb/ /" > /etc/apt/sources.list.d/crowdin.list
And your repository is ready for use. You can install the Crowdin CLI Debian package with:
sudo apt-get update && sudo apt-get install crowdin
To install the Crowdin CLI manually:
$ wget https://artifacts.crowdin.com/repo/deb/crowdin.deb -O crowdin.deb
$ sudo dpkg -i crowdin.deb
RPM
rpm --import https://artifacts.crowdin.com/repo/GPG-KEY-crowdin
Installing from the RPM repository
Create a file called crowdin.repo in the /etc/yum.repos.d directory containing:
[crowdin]
name=Crowdin repository
baseurl=https://artifacts.crowdin.com/repo/rpm
gpgcheck=1
gpgkey=https://artifacts.crowdin.com/repo/GPG-KEY-crowdin
enabled=1
And your repository is ready for use. You can now install Crowdin CLI with one of the following commands:
sudo yum install crowdin
sudo dnf install crowdin
$ wget https://artifacts.crowdin.com/repo/rpm/crowdin.rpm -O crowdin.rpm
$ sudo rpm -U crowdin.rpm
Standalone Version
Crowdin CLI can be installed as a stand-alone Java application.
Installation on Linux and macOS
  1. Download crowdin-cli.zip using the button above
  2. Unpack it
  3. Run ./crowdin.sh in the terminal with sudo rights in order to add crowdin command to your terminal
Installation on Windows
  2. Extract it's content to the place where you want Crowdin CLI to be stored
  3. Open Command Prompt as an Administrator
    1. Click Start
    2. In the Start Search box, type cmd, and then press Ctrl+Shift+Enter
    3. If the User Account Control dialog box appears, confirm that the action it displays is what you want, and then click Continue
  4. Run setup-crowdin.bat script in order to add crowdin command to the Command Prompt
  5. Restart your Command Prompt
Running the App
Use the following method to run the app:
$ crowdin
Alternative method:
$ java -jar crowdin-cli.jar
Configuration
To use Crowdin CLI you need to have a configuration file. We recommend to name it crowdin.yaml. You can create it running the command:
$ crowdin generate
When calling Crowdin CLI in terminal you should be in your project root directory. Otherwise, you will have to specify a configuration file path using the --config option:
$ crowdin upload sources --config /path/to/your/config/file
Run crowdin help to get more details regarding other commands.
Sample configuration file:
"project_identifier" : "your-project-identifier"
"api_key" : "your-api-key"
"base_path" : "your-base-path"
"preserve_hierarchy": true
"files": [
    "source" : "/en/**/*.json",
    "translation" : "/%two_letters_code%/**/%original_file_name%"
To get your project API key, use the Account Projects API endpoint.
For more information how to configure Crowdin CLI, check the Configuration File article.
Usage
Once the configuration file is created, you are ready to start using Crowdin CLI to manage your localization resources and automate file synchronization.
General Commands
To display help information:
$ crowdin help
To generate a skeleton configuration file:
$ crowdin generate
To check configuration file for general mistakes:
$ crowdin lint
To display a list of uploaded files to Crowdin:
$ crowdin list project
Uploading Resources
To upload source files to Crowdin:
To upload a single file without configuration:
$ crowdin upload sources -s path/to/your/file -t file/export/pattern -k your-key -i your-identifier
Use placeholders to put appropriate variables.
To display a list of files that will be uploaded to Crowdin:
$ crowdin upload sources --dryrun
To upload existing translations to Crowdin (translations will be synchronized):
$ crowdin upload translations
To show a detailed information about the upload command:
$ crowdin upload --help
Downloading Translations
To download latest translations from Crowdin:
$ crowdin download
To download latest translations for the specific language (language codes):
$ crowdin download -l {language_code}
To display a list of latest translations from Crowdin:
$ crowdin download --dryrun
To show a detailed information about the download command:
$ crowdin download --help
Versions Management
There is no need to run a specific command to create version branches if synchronization tool is used. The version branch will be created automatically during the files upload.
To upload source files to the specified version branch:
$ crowdin upload sources -b {branch_name}
To upload translations to the specified version branch:
$ crowdin upload translations -b {branch_name}
To download translations from the specified version branch:
$ crowdin download -b {branch_name}
See Also
Was this article helpful?
